08-14-2007, 04:21 PM | #21 | |
Rock Crawler Join Date: Mar 2004 Location: Where it's wet
I think the .035 wall is perfect. If you fall off a 5' cliff straight onto a sharp rock it might bend. 99% of the time it takes the abuse. Im not sure what it's going to look like till its done The design has evolved from my original idea... | |
08-17-2007, 11:28 PM | #22 |
Rock Crawler Join Date: Apr 2007 Location: portland
is that flux coated brazing rod?
08-18-2007, 08:28 AM | #23 |
08-21-2007, 03:43 PM | #24 |
I wanna be Dave Join Date: Jun 2004 Location: Whales
Have you looked at the Smith Mini Torch? It takes MAP and all sorts of other gases, heck you could run it off of Pinch's farts if you wanted too. It's small and very percise and only costs about $125.00. Thanks for the tips |
08-21-2007, 04:12 PM | #25 |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
| Build it right and it will take that fall and more. 3/16" is plenty for a super (who builds supers anymore anyways?). I dont like the way 1/4" kinks on every bend. i will post up a picture of what I am talking about when I say build it right.
08-22-2007, 07:41 AM | #26 |
Quarry Creeper Join Date: Jan 2006 Location: SLC
Is this thread done? Waiting for more pic's of a new chassis. Mike |
08-22-2007, 07:59 AM | #27 | |
http://store.cyberweld.com/sismsoou.html Looks like the ultimate setup May have to drop Santa a line... | |
08-22-2007, 09:52 AM | #28 |
This is what I was thinking: http://www.littletorch.com/kits.html Model #23-1014 There like $125 - $140ish They look like a great little torch. My dad uses one for jewelry work and the tips are easy to get and change and with it taking all kinds of gases it's pretty versital. The flame can be as small or large as you want depending on the tip. They also have a cool lighter that you just touch the torch too and a 9v. battery lights it up quickly. It's just a bench mounted rig. I've been thinking about getting one here shortly. |
08-22-2007, 11:07 AM | #29 |
Nice |
08-22-2007, 11:32 AM | #30 |
Pebble Pounder Join Date: Aug 2007 Location: Kennewick
Where does a guy pick up one of those Smith Torch's? I didn't see anywhere to order one on the site... thanks WaWa |
08-22-2007, 11:50 AM | #31 |
I found some on ebay and I'm working on finding them here locally in Utah. I've got a fever and the only cure is a Smith MiniTorch :-) |
08-22-2007, 12:37 PM | #32 |
I built a tuber a few years ago for my clod with brass and brazing... but I'd like to step up the home fab a touch. This looks like it would do the trick... WaWa |
10-04-2007, 08:29 PM | #33 | |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
So I can can plan ahead to avoid kinks, maybe do the sand idea I'm about to build with 1/4 stainless How's this build comin ? | |
10-12-2007, 01:17 PM | #34 |
Newbie Join Date: Oct 2007 Location: SoCal
great info thanks!! just got some materials to get some practice, bendin' & brazn'. to make fishmouth tube ends easier, do you make the cut at an angle or V to grind less post cut? |
10-14-2007, 11:21 AM | #35 |
Rock Crawler Join Date: Apr 2004 Location: Longmont, CO
I've got a smith "The little torch" oxy/acetylene torch. Bought it to make my tuber. Worked pretty good but to be honest I liked the plain old bernzomatic mapp gas torch better. The mapp gas is perfect cause it's very hard to over temp the joint. With oxy/acet I found the heat was to concentrated and I could burn off the flux before the heat was right. |
11-15-2007, 03:50 PM | #36 |
Rock Stacker Join Date: Nov 2007 Location: Clifton, VA
Great thread guys. If you have three pipe ends being joined together, do you have to braze them all at once or can you add one later?
11-15-2007, 04:25 PM | #37 |
11-16-2007, 08:39 AM | #38 |
RCC Addict Join Date: Mar 2006 Location: MUSE, PA
11-17-2007, 04:05 AM | #39 | ||
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
will it get brazing rod hot enough to use? and what flux would i use if any with regular rods from lowe's? i got some silver solder 50 1/8" and i am having trouble melting it. any suggestions? great writeup and thanks alot. | ||
11-26-2007, 04:30 PM | #40 |
RCC Addict Join Date: May 2006 Location: Roseville
I had a fire in my house a few months back and I just recently received my "soft" items back from the cleaners. They used many industrial hangers for many heavier items (looks to be 1/8 rod, perhaps a hair larger) and I am curious to know if the Mapp setup will work with this kind of rod. It will be my first project, so I am not really super worried on looks, just don't want to waste $.
