09-12-2007, 11:08 AM | #1 |
Newbie Join Date: Mar 2006 Location: Reggio Emilia
| Durafix For Alu Tuber...
Hello! i have one question: i have purchase the kit of "durafix" (rods and brush) but I not to know as it works. I have to read to the instructions and the video on website but the rods not to apply over to the aluminum. to be someone that using? I to use of the tuber from 10mm, 8mm, 6mm Many tanks! www.doctorcustom.com |
09-14-2007, 01:27 PM | #2 |
Help me!!!! i have the brazing aluminium problems!.... |
09-14-2007, 03:23 PM | #3 |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
dont use that stuff. google "harris al-cor brazing" that is the stuff to use. |
09-14-2007, 04:13 PM | #4 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
Durafix is great for filling holes...............sucks for holding stuff together. Harris Al-Cor, although difficult to work with (as with any al brazing), it will hold. |
09-15-2007, 04:45 AM | #5 |
| Durafix |
09-19-2007, 08:32 PM | #6 |
Quarry Creeper Join Date: Sep 2005 Location: Sydney, Australia
[quote=Robb;847452]Durafix is great for filling holes...............sucks for holding stuff together.quote] great on holes after a sand back but it ok on light duty holding. i brazzed 2 bits of aluminium angle to make a |___| shape. what i did was i beveled the 2 peices to to get more surface area to hold.i heated it up and ran the rod in the gap. got full penetration. its stengh was great. i tryed to snap it and it bent the aluminium then the started to crack. i wouldnt use it on a tuber. just tig weld it |
11-07-2007, 12:12 AM | #7 |
Newbie Join Date: Nov 2007 Location: Hillsboro,Oregon
this is what I use |
11-12-2007, 10:22 AM | #8 |
11-14-2007, 06:19 PM | #9 |
Newbie Join Date: Apr 2007 Location: davenport
there are a few products out that will braze aluminum, but they only stick to the exterior of the aluminum and into the exterior pours, none of them actually become part of the aluminum unless it is tig welded, mig welded and the elec ark melts the rod/wire into both pieces and cuases a united bond, i have used a few aluminum "solders" or brazers, but if you dont follow the instructions word for word, they dont work, stainless steel brushes only !! the MATERIAL needs to be hot enough to melt the rod, not the flame, and you really need some acid to clean the areas of weld before brazing.....
