| | #1 |
| RCC Addict Join Date: Dec 2004 Location: Central NY
| my pede tranny just came in today i need to to cut a rectangle in for the spur gear to stick out. what would be the best way of cutting it? |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Apr 2004 Location: Cincinnati Ohio
| Drill 2 holes in it, one at each end of the rectangle. Then use a dremel with a fiberglass reinforced cut off disk to cut out the rectangle in between the 2 holes. |
| | #3 |
| ok thats what i was going to do if no one replied to the post |
| | #4 |
| Colt Python/SR9c ![]() Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| no need to drill holes if your using a cutoff wheel dremel also has a titanium cutting bit.. it looks like a small bit for a mill..cost about $10 but works great.. i forget the actual name of it |
| | #5 | |
Yes you do, if your cutting a long skinny rectangle with a large cut off wheel. You can make the long horizontal cuts easily with a cutoff wheel, but how do you make the short vertical cuts? Last edited by AdamF; 04-22-2005 at 11:05 PM. | |
| | #6 | |
have you measured a pede tranny? you will not need to use a drill | |
| | #7 |
| Rock Crawler Join Date: Jan 2005 Location: and OR. if . . . . Gone Fishin :p :b :p
| Just take 4" grinder to it, you'll "Git ur dun" in no time! And make sure you use Saftey glasses or close your eyes |
| | #8 |
| ive already got the whole cut. i used the drill and dremel procedure. |
| | #9 | |
| I wanna be Dave Join Date: Jan 2004 Location: Flagstaff, AZ
| | #10 | |
| 06 Super National Champ ![]() Join Date: Jun 2004 Location: Tennessee
He's trying to cut a slot for the spur. | |
| | #11 |
| Yea...WTF are you smokin jeremy? |
| | #12 |
| hey you guys just do it your way and i'll do it mine |
| | #13 | |
| | #14 |
| yeah and that's if i don't break out the Plasma cutter first |
| Thread Tools | |
| Display Modes | |
