Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Starting to braze, did I buy the correct rod/flux?
Old 09-28-2007, 11:33 AM   #1
Default Starting to braze, did I buy the correct rod/flux?
Im trying my hand at brazing and Im going to make a roof rack.
Here's what I bought at home depot;
Mapp gas
bernzomatic plumbing flux
bernzomatic "bronze flux coated" brazing/welding rod. It says "for everyday repairing of steels, cast, coper based, galvanized, or any combo of these metals"
Did I screw up with the plumbing flux? Is there a difference with brazing flux?
The reason I got this is they didnt have a huge selection at the Home Depot and its right down the street.
Im using solid steel rod and some steel brake line.
Thanks
MG
webdr is offline   Reply With Quote
Old 09-28-2007, 11:42 AM   #2
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
It will work, I think it has a higher melting point than the safety silv 56 that most folks use.
Give it a shot, make sure the metal is super clean and that you dont burn the flux.
JohnRobHolmes is offline   Reply With Quote
Old 09-28-2007, 11:55 AM   #3
how do I not burn the flux? Dont you apply it to the joint before heat, then heat the joint?
or are you referring to the flux on the rod...
Old 09-28-2007, 12:42 PM   #4
If going to the HD is so convenient, take a closer look around there for the Lincoln Electric brazing rods (come in a long clear tube). Not as easy to work with as the Safety Silv, but many times easier than the Bernzomatic rods.
Robb is offline   Reply With Quote
Old 09-28-2007, 12:50 PM   #5
copy that, Ill look for them when I go back.
Old 09-28-2007, 02:36 PM   #6
take some time, find a welding supply shop and get harris safty silv- you will not be able to thank me enough.
the lincoln rods work, but for tubing I found the melting point to be way too high. it works on solid rod, doesnt look too clean but it works.
get the harris.
mrpink is offline   Reply With Quote
Old 09-28-2007, 03:22 PM   #7
get the harris.
Your statement is so true. I heated the tube till it glowed bright red and touched the wire to it....nothing...not hot enough. Im going to pick up some safety silver.
Thanks
Old 09-28-2007, 03:53 PM   #8
I've used the flux coated rods for tubers before. It works great but I use a big act/oxy torch to braze with. I found that the uncoated rods work, and flow flow the best. But what you have there will work.
'83 chevy is offline   Reply With Quote
Old 09-30-2007, 08:36 PM   #9
ghetto fabulous newbie
my local welding shop didnt have Harris silv 56 or the flux so i use UNIWELD. UNI-1000 flux and UNI-1056 silv its the same stuff, brazes awesome.
yotachump is offline   Reply With Quote
Old 10-03-2007, 03:56 PM   #10
Good find My local suppliers don't carry the Harris braze or flux, but definitely have the Uniweld. Properties seem to be very similar to the Harris stuff too.
ecoli is offline   Reply With Quote
