Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Harbor Frieght mill
Old 11-08-2007, 11:21 AM   #1
Default Harbor Frieght mill
I searched around but couldn't find anything about this. Has anyone seen this? I figure it'd be good for the occasional use I'd give it, and at $60, you can't beat that! I figure a good drill press with a end mill bit and this thing could get the job done. I'm planning on building a chassis for my WK, but don't want to spend several hundred (or thousand) dollars on a mill.
http://www.harborfreight.com/cpi/cta...emnumber=94276
any thoughts? Has anyone used this before?
jbrandt is offline   Reply With Quote
Old 11-08-2007, 11:30 AM   #2
[HOONIGAN]
Wrecker's Avatar
I've played with it at the store, there's a lot of slop in it.
Wrecker is offline   Reply With Quote
Old 11-08-2007, 12:56 PM   #3
hmm, that's no good. I guess you can't expect much more from a $60 mill!!
Would a band saw be a better option for cutting out a chassis? Not as precise as a mill, but would get the job done... What about cutting out pieces inside a chassis, a band saw can't do that...
what type of tool (besides a mill) could to that, a table mounted jigsaw type tool perhaps...???
thanks for the input!
Old 11-08-2007, 01:11 PM   #4
A heavy duty scroll saw. Just invest (save) for a better mill.
Cslax06 is offline   Reply With Quote
Old 11-08-2007, 01:22 PM   #5
A scroll saw would work good for light materials like acetal and wood. Aluminum may be a little slow depending on the grade but do able provided you have the right blade.
_BEN_ is offline   Reply With Quote
Old 11-08-2007, 02:01 PM   #6
a scroll saw, didn't think of that! that's a pretty good idea.
Hmmm, if my wife is reading this... take a hint - Christmas is coming soon!
Old 11-08-2007, 02:06 PM   #7
Picky Fab'r/Acetal Junky
Offroader5's Avatar
You could easily get the job done with a jigsaw. It all depends on what you're most comfortable using already really. I am pretty comfortable with my jigsaw on cutting out smaller pieces, so when I did my chassis (3/16" acetal), it worked great. You could use it for say 1/8" aluminum if your using a fine narrow blade in the jigsaw. Can always clean up the edges with a drum sander mounted in your drill press.
Offroader5 is offline   Reply With Quote
Old 11-08-2007, 03:04 PM   #8
Misslabelled item. This thing is awfull as a wannabee mill.
But awsome as a precision scrolling visse. Got one, perfect for hole alignement on small parts. There is usually less slope when you properly screw back everything in place... The shelf sample usually have a few missing parts.
Coligny is offline   Reply With Quote
Old 11-08-2007, 03:19 PM   #9
Drill presses should NOT be used as mills. They are not built to take the stresses.
Destroyer is offline   Reply With Quote
Old 11-08-2007, 03:35 PM   #10
That is a good point they are not really designed to take high lateral loads nor will they be able to controll the bit from hunting due to low tolerances. Ruining any accuracy.
But for very light materials like acetal they could pull it off if the project does not require much accruacy. I would not trust it for anything critical.
For what it is worth. I would rather invest into a cheap mill than a drill press.
http://www.billsbest.com/thatlas.html but that is my personal preferance.
Old 11-08-2007, 04:10 PM   #11
thanks guys! I think I'll save up for the "cheap mill" - much better idea than the crappy adapter thing from Harbor Freight... Plus, you can use the mill as a drill press! ha!
I think a scroll saw is in my near future. I have a jigsaw, but I find it hard to cut small pieces with it.
Old 11-11-2007, 04:52 AM   #12
I use a drill press as a milling machine,it works great with delrin but not too good on aluminum.I take it real slow and only remove small amounts of aluminum at a time.If I could afford to I would buy a "cheap" mill like the one shown above,and a lathe,and bandsaw and.........
red jim is offline   Reply With Quote
Old 11-12-2007, 05:47 PM   #13
toy4crawlin's Avatar
Harbor frieght is PURE CRap !
Amazon .com Palmgren cross slide vise
also Sears make one that looks identical
My Palmgren is execellent !, No slop, top grade
I use it in my drill press to do mill work, so nice
toy4crawlin is offline   Reply With Quote
Old 11-13-2007, 07:24 AM   #14
Can you post up a pic of your set up, Toy4Crawlin??
metomwhou is offline   Reply With Quote
Old 11-13-2007, 08:58 AM   #15
~THE SCALE SHOP~
ive cut lots of 1/8" aluminum with a jigsaw
STANG KILLA SS is offline   Reply With Quote
