Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Deanodizing parts
Old 11-06-2007, 07:29 PM   #1
Default Deanodizing parts
Hey guys, how are you deanodizing parts? I have AX10 and want to get rid of all the green for my scale build.
Ax-10Canadian is offline   Reply With Quote
Old 11-06-2007, 07:47 PM   #2
dezfan's Avatar
Try some Easy Off oven cleaner.
dezfan is offline   Reply With Quote
Old 11-06-2007, 07:48 PM   #3
Adilynsdad too!
braceysdad's Avatar
yep yep
braceysdad is offline   Reply With Quote
Old 11-06-2007, 07:57 PM   #4
how long should i let it sit for?
Old 11-06-2007, 07:58 PM   #5
Picky Fab'r/Acetal Junky
Offroader5's Avatar
JIA suggests using Greased Lightning...says it works great.
Offroader5 is offline   Reply With Quote
Old 11-06-2007, 08:06 PM   #6
i used the easy off yellow can, supposidly its the only one that works, but it did tarnish my metal, i just painted over it you could polish them after
ctrwannabe is offline   Reply With Quote
Old 11-06-2007, 08:24 PM   #7
Greased Lightning or Whink Rust Stain Remover work very well.
aggressivellc is offline   Reply With Quote
Old 11-06-2007, 09:28 PM   #8
Anodizing doesn't need to be removed before powdercoat does it? Just thought I'd tag my question on here rather than start a new topic.
Jamus is offline   Reply With Quote
Old 11-06-2007, 09:32 PM   #9
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Let the lye (easy off) sit on there for about 5-10 minutes depending on the depth of the ano and tempurature. Don't brethe the vapors or get the lye on your skin. Wipe it off every few minutes and see if it has hit metal yet. As soon as it is clean hit it with baking soda and water to polish and neutralize the lye. If you let it sit too long it will pit and corrode the aluminum too much.
JohnRobHolmes is offline   Reply With Quote
Old 11-06-2007, 10:46 PM   #10
ghetto fabulous newbie
learned that the hard way
yotachump is offline   Reply With Quote
Old 11-07-2007, 09:14 AM   #11
Greased Lightning
Even RCCaraction did a piece on it.
BrockGrimes is offline   Reply With Quote
Old 11-07-2007, 11:42 AM   #12
But does it dis-color the alumium and how long did you let it soak for
JUSTGOINGSLOW is offline   Reply With Quote
Old 11-07-2007, 11:45 AM   #13
In the whink rust remover
Old 11-07-2007, 12:06 PM   #14
Depends some times you just have to poor it on and let it sit for a couple of seconds.
Old 11-07-2007, 01:29 PM   #15
Id use Dran-o sink clog remover. Worked amazing and left a mirror finnish. I let them sit for about 45 mins.
Cslax06 is offline   Reply With Quote
Old 11-07-2007, 02:23 PM   #16
greaed lightning by far the best. non-toxic, won't corrode alum., will look good unless parts are made of cheap alum. i'd only use easy-off to strip chrome off of plastic. also depending on anodizing, only take 10-15 min to strip, rinse off. you can polish it to a shine with some alum. polish.
Hoser is offline   Reply With Quote
Old 11-07-2007, 04:05 PM   #17
Location: Taylors Falls just hanging with the MNRCRC crew.
Where can you pick up greased lightning? Whats its normal use?
Stormin2u is offline   Reply With Quote
Old 11-07-2007, 04:15 PM   #18
Its a degeaser. You can find it in walmart in the cleaning isle or in the automitive section.
It can also be found at most auto parts stores.
Old 11-07-2007, 04:18 PM   #19
What drain-o gel or just the old straight liquid
Old 11-07-2007, 05:38 PM   #20
I just did my axial kit a minute ago(don't tell my boss) I used a bead blaster, worked very well and left that nice matte finish on the aluminum.
Kamikaze is offline   Reply With Quote
