06-18-2012, 04:02 PM | #1 |
I wanna be Dave Join Date: Feb 2011 Location: Atlanta, GA
| Wheelworks Black-N-Tacky Gear Lube***IN STOCK*** Intense Racing Concepts is proud to carry WheelWorks' Black-N-Tacky Gear Lube! 1 (2oz) squeeze bottle $16 shipped CONUS PM me to order From Reflection (Wheel Works): I'm not going to try to impress anyone with big words or false claims. This stuff just plain works, that's it. It's a mixture of a few different oils and additives I feel are needed to provide a super slick grease thick enough to stay where it's needed, yet thin enough lubricate and keep the gears happy. Testing: I've put nearly 50 packs through my XR10 (box stock, besides a bushing kit) with zero failure. Roughly the same amount of run time in my sons XR10 (box stock, besides a bushing kit) with zero failure. That's impressive to me because he's got a heavier trigger finger than Dad does. Some decent run time in a Berg, with zero issues. Wondering what it would do in extreme heat.... Figured using it as a cutting oil on my lathe at work would produce WAY more heat than these little cars will ever do. So, I chucked up on a piece of 4" 316 stainless. Turning at 800 RPM'S taking .050" cuts. It did smoke some, not as much as I figured. When it gets hot, it gets stickier than it is at room temp. A bonus, if you get it hot enough, it smells like pancakes. NO, there's no maple syrup in it. Wondering what it would do in extreme cold.... Coldest thing I have available is a deep freezer that I put beef in. I placed a bottle in the deep freezer next to a side of rock solid beef for 3 days. The viscosity did get thicker. Zero signs of freezing or crystallizing at all. It warmed up quickly to room temperature and returned to it's normal viscosity. The squeeze bottles we have, they do have a tiny hole in the end. It's tough to get it to squeeze out. I know everyone prefers different, I ran a 3mm drill through the tip of my bottles to make it easier to come out. The option is there to make applying it easier for you. In an XR10, Berg, AX10 tranny or most other applications, I recommend 4-5 drops, roughly 1/4" in size per gear, that's it. ***GIVEAWAY*** Last edited by chicklet; 06-18-2012 at 04:17 PM. |
06-28-2012, 12:30 PM | #2 |
| Re: Wheelworks Black-N-Tacky Gear Lube***IN STOCK***
Thanks for the orders guys! Don't forget about the Giveaway posted above^^^ If you buy a bottle during the giveaway, you can choose another bottle or a refund of your already purchased BNT! |
07-18-2012, 05:17 PM | #3 |
Rock Crawler Join Date: Mar 2008 Location: amherst, ny
I received the black and tacky lube i won in your give away today! Great and fast service, thanks. Cant wait to tey it out!
07-19-2012, 11:27 AM | #4 |
Awesome! Enjoy!
07-19-2012, 11:45 AM | #5 |
RCC Addict Join Date: Nov 2009 Location: cleveland,Tn
great product bought some at our local comp from the maker... |
Wheelworks Black-N-Tacky Gear Lube***IN STOCK*** - Similar Threads | ||||
***Wheelworks Black-n-Tacky gear oil*** | Reflection | General Crawlers | 5 | 05-28-2012 12:43 PM |
gear lube | gearstripper | Newbie General | 19 | 01-28-2010 01:20 PM |
Gear Lube!!! | JeeperoManiako | General Crawlers | 3 | 04-14-2006 12:32 AM |
Gear Lube? | PastryLikeDood | General Crawlers | 3 | 03-30-2005 06:25 PM |
