Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Traxxas Crawlers
Thread: final drive ratio and maxx diff ratio?
Old 07-08-2005, 04:23 PM   #1
Default final drive ratio and maxx diff ratio?
ok im trying to find out what tranny to use for a crawler im wanting to build and im wondering whats a good final drive ratio without wheels and tires. im looking to make this with a lathe motor (integty 55t) and stock maxx differentials. but still beable to bash around at a bit higher speeds.
1) whats a good final drive ratio? (probly running jumbomaxx clawdawgs. and stock maxx diffs.)
2)whats the ratio of stock maxx diffs?
3) how do i calculate the final drive ratio? (spur/pinion ratio x trans ratio x diff ratio?)
mike5721947 is offline   Reply With Quote
Old 07-08-2005, 04:40 PM   #2
SEARCH or be flamed! It exists in the confines of this web site!
Try this;
maxx ratios
or this;
Gear Ratio Equation and Chart I Made for us Crawlers...
Hope this helps.
Jeepjunky is offline   Reply With Quote
Old 07-08-2005, 05:45 PM   #3
well i might use a stampede tranny (final drive is 2.72) so i would have to get 87/18 (stock spur/pinion gearing) and divide the final drive ratio by that right to get the ratio of just the tranny?
for some reason the spur to pinion ratio is 4.83 so would it be 2.72/4.83? or is it a misprint and the final drive ratio is acually the transmission ratio?
so doing it with the final drive ratio from traxxas site acually being the tranny ratio i have a 7.7248 from tranny input shaft to tire. then i also have 12/93 gearing of pinion and spur (7.75) that equals 59.8672 final drive ratio.
now im stuck trying to figure out the speed this should give with 6.25" tall tires.
but i dont know what motor i should run (not really wanting to run the lathe motor as i am also wanting some speed.) i was thinking a mag mayham but there discontinued. so what motor would give a good amount of torque but still have good speed (als whats a good ratio to do?
Old 07-10-2005, 12:30 AM   #4
lets start with this,
whats a good final gear ratio to run on a maxx sized crawler with the integy 55t lathe motor? maybe 65:1? come on someone has to know this stuff.
Old 07-10-2005, 01:58 AM   #5
I have run 63.2:1 (9T pinions / 72T spur) with maxx sized tyres which is very nice.
I ran a good dozen pack thru the truck with terra crusher tyres (almost 7" dia) and the 63.2:1 worked well. The 71:1 would be even better.
I am now running 71:1 (8T pinions and 72T spur) which is even nicer.
Any slower would be more of a hinderance than a help with the terrain we drive here.
Those links above are great for stock ratios.
MudCow is offline   Reply With Quote
