03-22-2009, 07:28 PM | #1 |
Pebble Pounder Join Date: Sep 2005 Location: Fruita
| Long Time Coming - Rock Maxx
So I started this build about 5 years ago. At the time, TwistedCreations was The Man on this page, and I got a lot of my ideas from him, particularly how to build the solid axles. Between moving twice and having two kids, the project just sat until a couple months ago, when I decided to make it a priority to finish it off. Anyway, my main goals were to keep the COG low, put as much weight forward as possible (hence the need for the carrier bearing in the rear d-shaft), use big steering servos with 4WS and do it all within a tube frame. A few specs:
The front axle: The rear axle: Front suspension: Rear suspension: Motor compartment: Side profile: And of course, a flex shot: |
03-22-2009, 08:05 PM | #2 |
Pebble Pounder Join Date: May 2008 Location: alberta
Well the traxxas has those ones from the summit that are pretty dam sticky and there freakin huge
03-24-2009, 11:58 PM | #3 |
Pebble Pounder Join Date: Apr 2006 Location: Mt Blanc; France
nice tubing work does the front steering links function well like this? is there any differential turning radius left to right due to the design?
03-27-2009, 08:05 PM | #4 | |
Thanks, it was my first shot at brazing. It really got easy after I got into it. Yes, it turns a bit sharper to the right than too the left. A better, more conventional design could be used with a smaller servo. But with this big thing, and the desire to mount it low and in a protected location, it's all I could come up with. | |
03-27-2009, 10:31 PM | #5 |
Quarry Creeper Join Date: Oct 2008 Location: Madera
Nice Truck Monsterz- I Like it alot! 4 the steering though- try dropping down to end or the servo arm + reset it perpindicular to the servo w/tires straight ahead (1st pic), of course you may have to nip 5+mm off long link to drivers side. That should equal the throw of the servo enough to trim it afterwards. . .Crawl it
03-28-2009, 02:34 PM | #6 |
03-28-2009, 02:46 PM | #7 |
Newbie Join Date: Sep 2008 Location: Dub jay
nice work! definitely different, brazing is a PITA when your learning..
03-29-2009, 08:47 AM | #8 | |
Yea, that would help. Then I could lessen the drop between the drag link and tie rod to keep the clearance. It would be easier with Revo knuckles, but until I have issues with my stock knuckles and CVD's, I'll keep running with these parts. | |
03-29-2009, 08:50 AM | #9 |
04-07-2009, 04:04 PM | #10 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| Yeah my head don't need to get any bigger huh Cory Thanks for the props though monsterz, mucho appreciato I still have alot of parts laying around and thought about making another one. Yours looks pretty good. You already mentioned it, but after you do have problems and break CVD's, I highly suggest switching over to revo axles and knuckles. Doing that, you would need to rework your axles some though, as the Revo steering knuckles are spaced further than the stockers. As for your speed, what is your gearing? If I recall right, I ran the stock GD600 pinion(18t i think) on the motor and then ran a 12t pinion off the GD600 to a 72 spur gear. But I ran a 27t motor also..If you switch to a 35t lathe, the reduction unit will keep your torque and give you more wheelspeed another trick is to build the 2 main axle tubes from 5/16" solid, then do your braces with 3/16" brakeline..I did this with the green tuber and it worked really well. Last edited by TwistedCreations; 04-07-2009 at 04:06 PM. |
04-11-2009, 04:18 PM | #11 | |
My gearing is exactly what you state above. I've been considering the 35t motor, because I can't really add any more cells, and changing the gearing with the 55t motor either up or down is going to hurt overall performance. I've also considered lowering the gearing more, and going to an even higher turn motor. | |
