Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Traxxas Crawlers
Thread: Rear Diff. Clicking Noise
Old 09-16-2004, 05:57 PM   #1
Default Rear Diff. Clicking Noise
When I go and try to drive over a rock, the rear wheels stop and there is a clicking noise coming from the rear differential. The front moves normally. The back driveshaft still spins but the wheels in the back don't nor do the axleshafts. What do you guys think is the problem? I've checked it 3 times for bearing, grease and chips but nothing seems to be wrong. I've also checked the slipper clutch to see if its too tight but it isn't. I also have a rear spool. If what you guys suggest doesn't work I guess i'll just buy all new gears. Thanks for the help.
E-MaxxMan is offline   Reply With Quote
Old 09-16-2004, 07:01 PM   #2
Ace
Default Re: Rear Diff. Clicking Noise
Dunno, maybe you stripped out the wheel hex's???
Ace is offline   Reply With Quote
Old 09-23-2004, 06:41 AM   #3
THat would most likely be the screws that hold the ring gear to the diff. sheared off. Or you stripped the ring/pinion.
Destroyer
Destroyer is offline   Reply With Quote
Old 09-26-2004, 09:41 AM   #4
Yeah, I looked at it more closely and there were 3 stripped teeth on the ring/pinion gear, so I'll get a new one sometime soon.
Old 09-26-2004, 05:48 PM   #5
i had the same problem yesterday i took apart the differential and one of the gears had a missing tooth so i just put jb weld in it and locked the differential it stopped clicking cause the jb weld sorta just filled in the missing part and i lock the front differential to and lock the slipper clutch that thing will crawl anywhere now. so instead of replacing it lock the differential instead it works better and give you positive traction all the way around.
skittle is offline   Reply With Quote
Old 09-26-2004, 06:08 PM   #6
Location: orange county n.y. , building the hydro crawler
skittle, id think it stoped clicking because there WAS NO MORE diff action after you locked it. and e-maxxmans ring pinion is the problem not a spider gear.
sambmx is offline   Reply With Quote
Old 09-26-2004, 06:16 PM   #7
ok just telling you what i did to fix mine just to try to help i don't like know everything about this stuff yet so ya your probly right
Old 09-26-2004, 07:15 PM   #8
does anyone know what the site is with the dual engine tmaxx, with solid rear axle and independent front? i cant find it...lol
jorDANK
jordanator62 is offline   Reply With Quote
