12-24-2005, 02:38 PM | #21 |
Quarry Creeper Join Date: Nov 2005 Location: fairfax
okay i got the motor mounted in it's place today. i guess the piece wasn't actually bent like i thought. it had some burs under it keeping it proped up some. here's some pics: |
12-24-2005, 02:47 PM | #22 |
since i had the tranny out i thought i'ld take a couple pics of the mod i made to lock it into a single first fear: 1st pic: open tranny with forawrd only conversion shaft. get rid of the reverse no need for it 2nd pic: i left the primary shaft that is connected to the spur in the tranny. took all the other shafts out. they are laid out just like they come out of the tranny. the gears just laying there are the second gear assemble and clutch. you can remove these you don't need them in the tranny either. 3rd pic: what you see is the first gear. thisis the end where the secong gear and shaft slid on. after removing them i drilled 3 small holes through the first gear and the gear behind it. then put 3 servo mounting self tappers through it. you have to drill close to the silver nut looking thing to stay in the gear behind it 4th pic: back side of the previously mentioned setup |
12-24-2005, 02:50 PM | #23 |
had to do a little front end remodeling. imagine my surprise when i had to put the 1/4 scale servo where the standard one was i knew it was gonna be bigger but i had never actually seen a 1/4 scale before i got more than this done today but i didn't get the pics yet. will get them up soon i still have another one to put in the back:? |
12-25-2005, 02:07 AM | #24 |
pics of everything i got done yesterday.
12-25-2005, 02:12 AM | #25 |
1/4 scale servo was interesting to mount. i am gonna make my own cell packs. there will be two 3 cells packs. one pack on the front arm and one pack on the rear that will be open. i am thinking that will help even out the weight side to side. now i have to remember where that link for making your own battery cells is. i can wire my batteries apart like that and then link them together right? |
12-26-2005, 02:33 AM | #26 |
okay before i go burning all this stuff together i have drawn a little diagram. does it look like i have everything right? don't feel like toasting anything if i can help it. by seperating the packs like this, how will it affect my charging? will the two packs still charge as one? |
12-27-2005, 01:51 PM | #27 |
okay so i just went ahead and had a go at it. got it all wired together and it works well. had to make one small adjustment compared to the other diagram. the previous diagram will only work if you don't want independant rear steering. and you will need a reverser in there somewhere too. all that would have been plugged into one channel. i had too wire it like the diagram below to get the rear to steer on it's own. you can see next to the RX where i had to break the continuous yellow wire and run the rear yellow wire and a black wire to the 3rd channel. and finally some pics of how it turned out on the truck. hope my moabs get here soon. it's almost ready for a test run |
12-28-2005, 03:46 PM | #28 |
Rock Stacker Join Date: Oct 2005 Location: Lynchburg
Cool, let us know when you get your first test run in. How is your weight balanced out? It looks like if I'm not mistaken, that you put the motor and tranny facing to the rear? Could you have turned it around to get the majority of the weight to the front of the rig, or is the majority of the weight already in the front?:? I am asking so many questions because I am build the same thing (t-maxx converted). Still waiting on my TR2 and revo knuckle/axle shafts to get here. Thanks, Chad |
12-28-2005, 08:41 PM | #29 | |
It even has good pictures Someone should sticky this to the how to section. Just a thought. Thanks xtremraptor Chad | |
01-04-2006, 02:54 AM | #30 | |
01-04-2006, 02:58 AM | #31 |
i had to do some modifying to the chassis i started with. as i sat and looked at it i just couldn't make myself like what was going on. the chassis was kind of heavy to start with. not only that but i think my COG way way too high. so instead of the search button, i used the refresh button last weekend check it out now: |
01-04-2006, 03:03 AM | #32 |
i also got the TQ3 all converted and set up. added my switch for the servo and EPA pots for front and rear. here's the exposed wiring |
01-04-2006, 03:09 AM | #33 |
here are some pics with the wires stuffed back in, the switch mounted and the EPA's all glued in their spots
01-04-2006, 03:10 AM | #34 |
and now a pic from outside the case. switch and EPA's mounted
01-04-2006, 03:21 AM | #35 | |
after i made the new chassis and remounted everything i think i have the wieght to the front now. especially with the rx pack i have to run. my REVO stuff is on the way.. .. already got the center shafts in but i am waiting for the arm shafts and knuckles. the new 2.2 MOAB's are gonna go too. they are too small for what i want. i have some LST's on the way. anyone interested in brand new MOAB's and HPI mesh rims? | |
01-04-2006, 09:31 AM | #36 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
very nice post ya got here.. good job on pics and details Just remember though, this ain't the For Sale section |
01-04-2006, 11:48 AM | #37 | |
That is basically the same thing that I did. I talked to people that said they did it, but with no real good description. Anyway, great job on the build up. Chad | |
01-04-2006, 05:32 PM | #38 | |
01-04-2006, 06:38 PM | #39 |
Ahh, ain't no big deal.. I just had to mention it |
01-04-2006, 08:06 PM | #40 |
Pebble Pounder Join Date: Aug 2005 Location: Kenosha
even though this is still not the for sale forum, when are you gonna put them over there, im VERY interested, let me know. thanks.
