10-31-2009, 06:40 AM | #1 |
Rock Crawler Join Date: Nov 2008 Location: Beloit,ohio
| Thinking of getting a traxxas summit
Those of you that have them. What if any issues have you had? What would you change first,I mean what area would you upgrade to make it better? Thanks for your replies in advance. |
10-31-2009, 09:26 AM | #2 |
Quarry Creeper Join Date: Nov 2008 Location: morristown
mine is stock and i have only broke a rear axle
10-31-2009, 09:35 AM | #3 |
what part did ya brake? what was ya doing wen it broke?
11-06-2009, 08:59 AM | #4 |
RCC Addict Join Date: Jul 2008 Location: Sin City
The only things i ever broke in mine were a couple front driveshafts and a front shock pushrod. And those were all from me being rough on it since i dont think traxxas intended 15-20 foot rock jumps off the side of a wash into the rocks at the bottom.
11-06-2009, 05:49 PM | #5 |
Quarry Creeper Join Date: Feb 2008 Location: Pittsburgh PA
my friends got one he might sell it hasnt been drove much at all its pretty awesome i like it alot only upgrade i think i would do provided i had the money would be to do a different motor esc combo so you can use just one battery at a time to get longer run time. but you really dont need to tho i performs quite well and the selectable diff lock is right on. Last edited by BansheeManiac; 11-06-2009 at 05:58 PM. |
11-06-2009, 11:33 PM | #6 | ||
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
11-07-2009, 02:33 PM | #7 |
Actually, you can run the EVX2 on a single pack if you make a jumper to put on the non-BEC wire. Pretty easy to make too.[/QUOTE] can you post a pick of this..... thanks |
11-07-2009, 05:43 PM | #8 |
Rock Stacker Join Date: May 2005 Location: West Bend
I don't have one of my own but I've driven a friends quite a bit. The seem to be tough as nails and can take some abuse. Nothing has broken on it yet.
11-07-2009, 05:52 PM | #9 | |
can you post a pick of this..... thanks[/QUOTE] All you do is take a TRX female connector and solder each end on a single piece of wire (jumping both contacts together). Think of it as removing the non-bec plug and connecting the red and black wires together. If you make a jumper plug, you can always unplug it and run 2 packs again. | |
11-07-2009, 08:13 PM | #10 |
| All you do is take a TRX female connector and solder each end on a single piece of wire (jumping both contacts together). Think of it as removing the non-bec plug and connecting the red and black wires together. If you make a jumper plug, you can always unplug it and run 2 packs again.[/QUOTE] Yea, it's been a while since I helped somebodu with one, I want to say it needs to be put on the plug that goes to the left side battery |
