Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Traxxas Crawlers
Thread: Adapter to 12mm hex?
Old 02-12-2012, 01:05 AM   #1
Default Adapter to 12mm hex?
Does anyone make these so you can put a 2.2 wheel on a Summit?
kranswall is offline   Reply With Quote
Old 02-12-2012, 03:56 AM   #2
Status...ADDICTED!
ceedawwg's Avatar
Default Re: Adapter to 12mm hex?
A 2.2 wheel will not clear the steering knuckles/hubs on a 1/10 Summit...if you're talking 1/16 they are already 12mm.
ceedawwg is offline   Reply With Quote
Old 02-12-2012, 05:25 AM   #3
Slayer wheels fit, as long as you put the emaxx hex on there.
Gula is offline   Reply With Quote
Old 02-12-2012, 08:13 PM   #4
Status...ADDICTED!
ceedawwg's Avatar
Aren't E-Maxx Hex's 17mm? Not to mention Slayer wheels are 2.2/3.0...not straight 2.2
Old 02-12-2012, 08:47 PM   #5
Ah thanks ceedawwg, that makes sense. I guess if it could have been done we'd see em driving around.
Thanks for the tip Gula, they do make some scale looking 2.2/3.0 right? Like the BFGs?
Old 02-12-2012, 08:50 PM   #6
666
MODERHATER™
666's Avatar
You could drill out hexes to fit, or get hexes that fit Super 300 cvds to run 12mm hexes. And if you use rims that have the hex all the way out you will be golden.
These should fit: http://www.rccrawler.com/forum/vendo...uper-300s.html
666 is offline   Reply With Quote
Old 02-12-2012, 09:24 PM   #7
I think Teckno has 12mm hexes for 6mm shafts for use with their Slash/Pede 4x4 driveshafts.
BJoe is offline   Reply With Quote
Adapter to 12mm hex? - Similar Threads
12mm wheel adapter for Bruiser TamiyaFreak 2.2 Scale Rigs 1 03-11-2011 09:40 PM
12mm-17mm adapter NoblesvilleKid General Crawlers 6 07-03-2008 07:40 PM
12MM Hex Hub Adapter jmizoguchi Axial AX-10 Scorpion 3 11-26-2007 03:13 AM
