01-30-2005, 02:04 PM | #1 |
Pebble Pounder Join Date: Oct 2004 Location: ny
| maxx ratios
dose anyone know the ratio of a maxx diff.. i think its 3:1???????and whats a good crawl ratio for a mxx crawler?? thanks Chaos |
01-30-2005, 05:16 PM | #2 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
i think its either 2.7 or 2.8 cant remember for sure just did a "SEARCH" and found the tranny is 2.7 and the diffs are 2.8 i think mine is like 65:1 ratio, but depends on what motor you have.. my lathe motor on 1 battery makes it alot slower than that.. my top speed is like 3-4 mph Last edited by TwistedCreations; 01-30-2005 at 05:23 PM. |
01-30-2005, 07:13 PM | #3 |
Rock Crawler Join Date: Dec 2004 Location: Land of the Free, because of the Brave
| Twisted is right, diff ratio: 2.84:1 1st gear: 2.76:1 2nd gear (in case you're wondering) 1.72:1 I'm using a lathe motor, GD-600 (2.5:1), 76T spur and 9Tpinion (robinson racing). Hope this helps... |
01-30-2005, 08:12 PM | #4 |
yea that dose thanks except im going a little diffrent on the trans. im using a sportmaxx tranny i think the ratio is 2:1 or something like that i put on a stock pede spur and im using a 13t pinion. ( a gear ratio in the trans is how many times the spur goes around for the driveshaft to turn once right???)if so thats my ratio.. thanks again for you help.. Chaos |
01-30-2005, 08:42 PM | #5 |
to get your ratio divide the pinion into the spur then multiply that by the trans then multiply that by the diffs then thats your ratio ;) alot easier |
01-30-2005, 10:56 PM | #6 |
if that works my ratio is 36.45.....(but i dont know what that means lol Chaos |
01-31-2005, 06:38 AM | #7 |
that means you have a 36:1 crawl ratio,which is still kinda fast but if you use a lathe motor, that also help slow it down. also, you said you were using a pede spur gear? isnt that a 48 pitch gear? why use that? a 32 p is stronger :? |
01-31-2005, 07:21 AM | #8 |
the only pinions i have for that are like 19 t Chaos |
01-31-2005, 09:23 AM | #9 |
well if your set on using 48p gears,,,go get a 12t pinion and a 96( i think thats it) spur gear..im running those on my sons pede tranny..but since your running maxx stuff, go get a 72spur gear for a maxx( 32pitch) and a 9t pinion ;)
01-31-2005, 09:44 AM | #10 |
i just finished the lower links and i put it togeather for a test and it dosent go very fast it should be a good crawl ratio.. Chaos |
