10-05-2015, 04:40 PM | #1 |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
| Metal-gear micro servos for Summit -- SOLUTION FOUND
The transmission shift servo on my Summit crapped-out last night -- just locked up tight as a drum and then stripped itself out so I can hear the motor whizzing away constantly, trying to turn gears that no longer have teeth on them. I'd like to replace them with metal-gear servos, but I can't find metal-gear micro servos that have the standard Futaba 25-spline hubs that the stock servos use. I've looked at Hitec, Futaba, and Savox. Am I missing something? What are other people using? I'd really prefer to replace the stock micro servos with metal-gear servos that have the Futaba 25-spline hubs, because that way I can keep the stock servo-savers for the diff-lock servos. Alternately, if anyone knows of adaptors that fit onto micro-size servo hubs and adapt them to the Futaba 25-spline size, that would work fine too. Help? Last edited by fyrstormer; 10-31-2015 at 12:13 PM. |
10-07-2015, 12:28 AM | #2 |
| Re: Metal-gear micro servos for Summit?
Nevermind, I think I found a good solution. I'll know in a few days when it arrives.
10-07-2015, 02:08 PM | #3 |
Newbie Join Date: Jun 2015 Location: Dixon
Please let me know how it goes. I've been having the same problem as yours, except 6 times in the last 4 months and it's always the on for shifting the transmission, the other two have been problem free. I've looked some but hadn't been able to find a better replacement.
10-08-2015, 10:03 PM | #4 |
Newbie Join Date: Oct 2014 Location: Earth
Same here. I have killed 2 trans shift servos now. I want to replace them with better ones, but I can not find any that fit and work with the stock servo horns. Also I need them to still be water proof. |
10-09-2015, 12:51 AM | #5 |
Finding one that's already waterproof is the dealbreaker. Fortunately it's not hard to waterproof a servo. 1) Open the back end and paint the circuit board with clear nail polish (or colored nail polish, if the color helps you notice spots you missed); 2) Open the front end and make sure the gears are thoroughly greased; 3) Some people fill the middle area, where the motor and potentiometer are, with grease as well, but thus far I've skipped that step and I've had no problems. Unless you're running in saltwater (pro tip: NEVER DO THIS WITH ANY RC EVER), a drop of water in the middle section of the servo should make no difference; 4) If the servo isn't gasketed, use a toothpick to apply a bead of Loctite around the edges of the servo case before reassembling; the Loctite will form a thin seal to help keep water out. Hopefully the servo I ordered will arrive early next week. I'll post which one I got if it fits and if the direction of rotation is correct. I'm not trying to keep it a huge secret, I just don't want to waste people's time until I know for sure it works. I've seen too much idle speculation around the internet about which servos will fit, and I don't want to add to the morass. Last edited by fyrstormer; 10-09-2015 at 12:54 AM. |
10-12-2015, 11:30 PM | #6 |
The Turnigy BMS-211DMH (rebranded Blue Bird digital coreless servo) does not fit. The hub is the right size and the right spline-count, and the width is and thickness are right, but the mounting depth on the servo is too deep. Strike one; on to the next possibility.
10-18-2015, 04:12 AM | #7 |
Another problem with the BMS-211DMH is that it's coreless and digital, so it runs at full power constantly to maintain its position, since coreless servo motors have minimal resistance to rebound force from servo-savers, and there's no way to adjust the EPAs on the micro servos using the stock Summit radio. An analog servo with an iron-core armature may in fact turn out to be the best bet, and if so this will be the first time I've ever said "this servo is too fancy for this application." Someone I'm corresponding with on another forum says the second servo I'm going to try does fit; I'll confirm when mine arrives. |
10-19-2015, 10:55 PM | #8 |
Keep us updated man! I just replaced my shift servo again! Gears stripped in it again. And yes I have the end points set correctly. And the shift shaft moves free. This time a small Stick got in there and jammed the servo up. Just bad luck I guess. |
10-28-2015, 10:30 PM | #9 |
My servos finally arrived. I'm swapping back and forth between the analog and digital servos to get an impression of which ones I want to use. The digital servos are definitely noisier at first, but they do settle down after a few seconds -- having an iron-core motor does seem to help with holding their position, as I originally predicted. The digital servos also move into position faster and stay in position when I torque the hub using a hex driver. However -- and this is the $80 question -- I'm not sure those attributes actually matter for this application. For now I'm using the analog servos. I didn't really have any complaints about the performance of the stock servos, only about their durability. The new servos are definitely better-built, though I find myself wondering if I should buy a complete replacement set (instead of a single spare) just to be on the safe side, since Blue Bird isn't exactly a huge brand-name. Anyway, here's a picture of the servos installed, with 6" extenders on all the wires: The analog servos I decided to use are the Blue Bird BMS-373MG. The digital servos that I decided to send back -- but they do fit, if you really want digital servos for such a simple job -- are the Blue Bird BMS-375DMG. Last edited by fyrstormer; 03-29-2018 at 11:53 PM. |
01-17-2017, 12:27 PM | #10 | |
Pebble Pounder Join Date: Mar 2007 Location: Northern Ontario
| Re: Metal-gear micro servos for Summit? Quote:
The shifting servo on my Summit finally let go and I had a TGY2-212DMH in my box. It's the same dimensions as the 211 but faster with less torque. I use these for steering on 1/12th and F1 pan cars. Anyway, since I had it I decided to put it in. It's been in there over a year now and still working. I can't remember having any depth issues when I mounted it though. I can take some pics later this week when I get home. Sean | |
01-17-2017, 04:48 PM | #11 |
Hmm. It never occurred to me to use a micro servo on a race car to save weight.
01-17-2017, 06:26 PM | #12 | |
https://youtu.be/MiCv9tUceYs I'm going to try the 211 in my Summit as soon as I get one. Sean | |
01-18-2017, 03:23 AM | #13 |
Just keep in mind you don't need fast servos for shifting and diff-locking duties. Honestly the cheapest servo that fits and doesn't break is all you need, and since they will be straining against servo-savers constantly when they're in-operation, analog servos actually work better because they don't strain with their full strength against the slightest resistance.
01-18-2017, 11:16 AM | #14 | |
I have to admit I'm a bit of a servo junkie and every time I order from HobbyKing I always throw in a few cheap servos to test. Sometimes you find a real diamond in the rough. That's how I discovered the 212 for 1/12th pan cars. Sofar this servo has lasted longer than the Traxxas 2065 that it replaced. I don't know about other Summit owners but my servo just stopped working. When I disassembled it the gears were fine so I suspect the motor or the driver failed from always straining against the servo-saver. The 211/212 has a coreless motor but it also has an aluminum body to dissipate the heat. This would all go away if the radio had EPA for those shifting channels. Sean | |
01-19-2017, 03:15 AM | #15 |
EPAs would be nice, but let's face it, Traxxas radios are all RTR-grade, even the 5-channel one that comes with the Summit.
01-19-2017, 09:17 AM | #16 |
Wishful thinking. Sean |
04-28-2019, 11:25 PM | #17 |
Newbie Join Date: Dec 2018 Location: Rapid City
So it appears that the BMS-373MG has been discontinued by bluebird :( I can only find them on RcMart or Hobbyking from China.....
05-08-2019, 11:14 AM | #18 |
Traxxas really ought to make a metal gear set for their micro servos.
05-08-2019, 12:17 PM | #19 |
Newbie Join Date: Sep 2018 Location: NE Indiana
| Re: Metal-gear micro servos for Summit? |
05-08-2019, 12:41 PM | #20 | |
| Re: Metal-gear micro servos for Summit? Quote: Edit: found that too https://traxxas.com/products/parts/2064X Last edited by Natedog; 05-08-2019 at 03:14 PM. | |
Metal-gear micro servos for Summit? - Similar Threads | ||||
Is there a metal upgrade gear for the 80T spur gear? | maddogs1965 | Axial Wraith | 9 | 03-25-2014 11:31 AM |
High torque metal gear micro servos..why not? | miller | Electronics | 6 | 02-14-2008 10:06 PM |
metal gear for txt-1 centre gear box??? | satin's truck | Tamiya Txt-1 and Juggernaut | 12 | 11-12-2006 11:59 AM |
