Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Traxxas Crawlers
Thread: summit front end weights??
Old 10-25-2016, 09:45 PM   #1
Default summit front end weights??
does anyone make weights to mount to the front end of the summit for better climbing? yea i know i can add lead but i wanted something that looked more finished.
twisted is offline   Reply With Quote
Old 11-30-2016, 06:28 AM   #2
Default Re: summit front end weights??
Demount the tire and put the weights inside the rim or better yet buy a second set of front tires and rims and weight the new ones. Use the normal set for high speed bashing and the weighted set for crawling. Weighted tires are hell on the drive line at 25MPH
xCoolHandLukex is offline   Reply With Quote
Old 05-08-2017, 10:03 AM   #3
This thread has a pic of the knuckle weights I made in case you are inspired to make your own.
A Few Upgrades - Top, No-Slop Tranny and Knuckle Weights
On a Summit, adding weight to the wheels adds quite a bit of stress to an already marginal drivetrain. Also, if you ever drive it very fast, wheel weights will throw off your wheel balance a lot. You can always add weight to the chassis/body, but then it's up high and will affect handling. Really, the best places to add weight are to the knuckles themselves, or to the lower control arms.
monsterz is offline   Reply With Quote
summit front end weights?? - Similar Threads
Added Weights vs. Spare Tire Back End relay1 Axial Yeti XL 8 04-28-2015 07:54 PM
Summit front end in a rock racer????? dan1061986 Traxxas Crawlers 6 12-03-2013 10:27 AM
BBs or some kinda front end/ tire weights Jeepernick General Crawlers 16 05-12-2006 05:03 PM
