![]() | #1 |
Rock Stacker Join Date: Feb 2005 Location: portsmouth
I finished my maxx crawler, but when I hit the throttle the center of the chassis twists. Problem # 2 I have no turning radius. do you guys have any recommendations
![]() | #2 |
Rock Crawler Join Date: Dec 2004 Location: Land of the Free, because of the Brave
| ![]() Do you have 4 wheel steer set up? Either way, this is how to get a tighter turning radius on a maxx: Take off all four axle carriers (pillowball mounts) and use a dremmel tool to shave some of the plastic off from where the pillow ball shaft sticks through. This will allow the pillowball more freedom of movement, thus, tighter turning radius. |
![]() | #3 |
Rock Stacker Join Date: Dec 2004 Location: in limbo
shaving the link ends will not give more turning radius...you will need a longer servo horn or find a better place for the servo....as for your chassis twist try different shock possitions
![]() | #4 |
right now my shocks are mounted about an inch higher than the lower link mount, should I raise the shock mount?
![]() | #5 |
so is it mounted from the chass to the link or axle?
![]() | #6 | |
| ![]() Quote:
![]() | #7 | |
| ![]() Quote:
![]() | #8 |
[QUOTE=WRMorrison][COLOR=DarkOrange][SIZE=2][FONT=Comic Sans MS]Do you have 4 wheel steer set up? Either way, this is how to get a tighter turning radius on a maxx: Ive got to get my front steer set right before I try to tackle the rear steer. I figure once I get the front right the rear should be a sinch. I did do the mod to the tq3 and tested it and it works good. Instead of doing the standard toggle switch on the third channel I put 2 momentary push buttons on and I like better. |
![]() | #9 |
here is what I have done so far, give me feed back. I will get some pics asap. 4linked maxx but still needs work on link locations. evx single motor/battery mod tq3 mod but no 4 wheel steer yet gd-600 with titan until lathes get restocked locked out tranny(1st gear) locked out f/r diffs still running original maxx suspension just till I work out all the bugs wheel base is about 14 inches but probably gonna stretch it out a bit let me know what you think I need to do |
