Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Traxxas Crawlers
Thread: TRX-4 Sport - hill hold
Old 06-02-2019, 06:40 AM   #1
Default TRX-4 Sport - hill hold
Hi everyone,
I just bought a TRX-4 Sport and set the ESC to crawl mode (5 blinks).
Normally the esc should have hill hold to keep the car from going forward on an incline.
Does this feature block the wheels 100%? I noticed the car still rolls slowly on steeper inclines (+15% I would say).
I’ve made a small video:
https://youtu.be/z2-Km0DjPCc
Is this normal?
FYI, I’m running a 2s lipo. I tried a 3s lipo, but this doesn’t change anything.
dempy is offline   Reply With Quote
Old 06-02-2019, 09:53 AM   #2
Default Re: TRX-4 Sport - hill hold
Ya, that’s rolling a little to easy on my opinion. I would try resetting to first mode and than crawl mode (5 blinks). See if that helps
lkvisser is offline   Reply With Quote
Old 06-03-2019, 05:40 PM   #3
I would not spend much time messing with the stock ESC. Just up upgrade to the HW1080 ESC. BTW, the HW1080 and stock Titan 550 21t motor make for a surprisingly nice combo.
Inspector86 is offline   Reply With Quote
Old 06-04-2019, 01:30 PM   #4
Mine was all stock.., added an external bec and finally a cheap Arrma servo. Seems fine so far...,
Old 06-12-2019, 11:02 AM   #5
Did you ever find a fix?
Just had the same issue on my SCXii.., my throttle adjustment on my radio was set too high.., powering the rig just enough to let it roll down any inclines; neglecting the drag brake.
Old 06-12-2019, 12:31 PM   #6
My drag brake works just okay on mine, at least forward. Reverse is really weak though.
HW1080, 100% brake and freewheel, Crawlmaster Expert 16T.
Sure crawls over everything though.
Browneye is offline   Reply With Quote
Old 06-12-2019, 02:56 PM   #7
The strength of the drag brake is a function of the gearing and the sport is geared higher than a 2 speed TRX4 (using 1st gear) so its bound to be less effective. The stock setup is just not strong enough to hold the truck 100% still.
Your drag brake is definitely working its just weak, a better motor and ESC can improve it. Though the stock motor isnt bad at all, start with and ESC if you replace anything. Also try to reset it to mode 5 again as suggested above just to be sure.
EDIT: Hill hold is just a bad name for this, on the first release they were referred to as 70% and 100% drag brake IIRC
HumboldtEF is offline   Reply With Quote
Old 06-12-2019, 03:24 PM   #8
Hasn’t responded since first post....
... his time zone may be slightly different
Old 06-15-2019, 01:28 AM   #9
Thanks for the help guys.
I am in a very different time zone, but I have just been out of the RC game for a few weeks because of other priorities.
I have ordered another pinion and spur gear to lower the gearing and make the “hill hold” function more effective. The parts should be here in a week or 2. After testing I will update in this tread.
Old 06-15-2019, 06:24 AM   #10
Look at you acting all mature and such
Old 06-16-2019, 04:11 PM   #11
Not to be "technical", but you should be raising the gearing to make the hill hold function more effective, meaning the gear ratio should be a higher numerical value than what you started with.
dungeonracer is offline   Reply With Quote
Old 06-18-2019, 04:12 PM   #12
A "lower" gear has a higher numerical ratio and also increased braking. This is why you downshift a manual transmission to a lower gear in order to increase engine braking in a full sized car for example. The term "lower" refers to the relative speed of the driven gear as the drive gear , running at a constant RPM, gets smaller. If you're going to be "technical" you need to be "accurate".
Old 06-18-2019, 06:53 PM   #13
Whatever...
Pretty sure I was "accurate" when I stated....
Old 06-19-2019, 06:55 AM   #14
Ya, that's called 'lower' gearing.
Old 06-25-2019, 09:42 PM   #15
I initially went from the stock 17/39 to 14/45 gearing using Traxxas parts. But, you also need to buy the #8254 Rebuild Kit to get the slipper pads (stick-ons) for the new spur gear. Huge improvement. Later, I installed a Hobbywing 1080W ESC for all its adjustable parameters. Maybe $75 for all.
Still Bill is offline   Reply With Quote
Old 08-09-2019, 09:10 AM   #16
Whatever...
Which is lowering the gearing.
You said "raising the gearing."
So no, you weren't accurate.
keecrawler is offline   Reply With Quote
Old 10-19-2019, 09:45 PM   #17
This!!!
I put an HW1080 in my Everest 10. The ability to fine tune the settings yourself, and the great drag brake/hill hold really makes it stand out. $40 or so on Amazon...or most other places.
I'll own a TRX-4 sport myself someday. When that day comes, I'll put an HW1080 ESC into it. The tune-ability alone is worth every penny!
nymtber is offline   Reply With Quote
TRX-4 Sport - hill hold - Similar Threads
Does adding brass affect the Hill Hold Brake? Uncoiler Traxxas TRX-4 23 03-25-2019 05:24 PM
TRX-4 Sport 4RunnerKid Traxxas TRX-4 104 08-29-2018 08:59 PM
Traxxas trx 4 sport vs redcat gen 7 sport part 2! shenlonco Scale Videos! 0 08-03-2018 06:31 AM
Traxxas trx 4 sport vs redcat gen 7 sport! shenlonco Scale Videos! 0 07-23-2018 07:19 AM
