01-10-2020, 10:40 AM | #1 |
Newbie Join Date: Jan 2020 Location: Athens
| Lowering my trx4 sport
Hey everyone. New to the forum. The area we crawl has a lot of steep inclines and rocky areas and the truck seems to tip a lot more than I’d like. I’ve got some brass for it but I was wondering how you guys lowered your sports to help with that. Sent from my iPhone using Tapatalk |
01-10-2020, 11:03 AM | #2 |
Newbie Join Date: Nov 2019 Location: USA
| Re: Lowering my trx4 sport
I watched the YouTube videos from Harley Designs on the TRX 4 Sport budget build. Had some great tips on trimming the body so as to lower it and move the bumpers inward while also raising the rock sliders so the don't get hung up. I did these free mods and put the brass covers on the front portals. I'm very happy with the results. I also did the tire lug trimming which helped the stock tire traction a whole bunch.
01-10-2020, 12:13 PM | #3 | |
| Re: Lowering my trx4 sport Quote:
I'm running a Brazin Scale RC "All Time Low" G10 chassis that was designed for the TRX-4. It will shorten the wheel base to 12.3" and sit a bit lower using the stock shocks (90mm). Best of all it will be lighter and the performance is greatly improved. Bad news is the chassis and associated printed parts total cost is about $200. Good luck ... the TRX is a great performing Portal Axle vehicle at a reasonable price. It also is easily improved. | |
01-11-2020, 07:15 AM | #4 |
Changing around the shock mounts gives you some flexibility. GPM lower mounts work out great on my rig...looking to change around the towers as well to give me some more options. Running some droop shocks will also sit the truck lower... |
01-12-2020, 01:00 AM | #5 |
Rock Crawler Join Date: Nov 2011 Location: Paradise, ca
I run the factory shocks on mine with now spring tension and on class 1 rc4wd mtrs and mine sits low and plenty of flex
01-14-2020, 08:41 PM | #6 | |
Do you have a link to those? I tried looking them up but just kept showing bumper mounts and stuff. Sent from my iPhone using Tapatalk | |
01-15-2020, 06:44 AM | #7 |
PN TRX4019A-x (front) and TRX4013CA-x (rear) - where x is the color code. R=red, B-Blue, etc. Front: https://www.ebay.com/itm/TRAXXAS-TRX...AAAOSww~VeFPMc Rear: https://www.ebay.com/itm/TRAXXAS-TRX...wAAOSwR4peFPDk I'm sure there are various colors available in this seller's store, just a link to the first ones I found. |
01-15-2020, 07:00 AM | #8 | |
Thank you so much. Love your build threads by the way!! Sent from my iPhone using Tapatalk | |
06-13-2020, 06:32 PM | #9 |
Newbie Join Date: Mar 2020 Location: Canada
I did the pen spring mod, dirt cheap. Found it helped. Sent from my SM-G930W8 using Tapatalk |
06-15-2020, 05:04 PM | #10 |
Rock Crawler Join Date: Feb 2020 Location: Fort Leonard Wood
Hot racing sells shock mounts that allow you to raise your shocks therefore lower you TRX 4. I am sure there are other companies also that sell these. Play around with your preload rings on your shocks. Get a smaller battery. If you keep the rack and a bunch of stuff on it it will be tippy. Run a line were you tip with your body on and do it again with you body off and see if there is any difference. You don't have add every piece of brass you can find. You don't have to have a heavy TRX4. Mine weights about 7.5lbs with a battery BUT I am not into on the scale stuff, I am function over form. If you want to put looks ahead of performance and add all sorts of stuff you will probably need to add all sorts of weight as low as possible. It is about what you want. There is no correct answer, just trade offs. |
06-20-2020, 04:51 PM | #11 | |
DO NOT BUY Hot Racing shock mounts! The panhard mount is a single shear design with a small cross section of material making it weak and will eventually break off in normal driving. Last edited by Inspector86; 06-20-2020 at 04:54 PM. | |
06-22-2020, 05:11 AM | #12 | |
What did you replace it with? | |
Lowering my trx4 sport - Similar Threads | ||||
TRX4 or TRX4 Sport Kit? Help please. | m4inbrain | Traxxas Crawlers | 13 | 09-01-2021 07:47 AM |
TRX4 Sport, help!!! | Scissor34 | Traxxas Crawlers | 24 | 10-09-2019 09:26 AM |
TRX4 Sport body on TRX4 Crawler kit chassisc | redpeppers | Paint and Body | 7 | 09-14-2019 12:59 AM |
Trx4 kit or trx4 sport | mebeknob | Newbie General | 10 | 09-26-2018 10:38 PM |
