Trx4 sport 12mm hub extension problem Hey everyone, I recently ordered some brass 12mm extended hubs for my sport. They fit perfectly but when I put the wheels on, there isn’t enough thread to torque down the wheel nut. Is there an extended axle shaft I can buy or something that will make them fit right? Thanks guys for all your help. Sent from my iPhone using Tapatalk |
Re: Trx4 sport 12mm hub extension problem Barrel nuts Sent from my SM-G970U using Tapatalk |
Re: Trx4 sport 12mm hub extension problem Quote:
Barrel nuts? Sorry, still new to the hobby. I’ll try and see if I can look up what you’re talking about. Sent from my iPhone using Tapatalk |
Re: Trx4 sport 12mm hub extension problem They will be similar to these https://images.app.goo.gl/PSLsFaq33PyypAZSA Sent from my SM-G970U using Tapatalk |
Okay cool. Never seen those before. Sent from my iPhone using Tapatalk |
Re: Trx4 sport 12mm hub extension problem A few people have said that ordering the bronco axle shafts will make them fit also. So may go that route. Sent from my iPhone using Tapatalk |
But, do what you want, it's your money. Sent from my SM-G970U using Tapatalk |
Re: Trx4 sport 12mm hub extension problem The Bronco and Blazer portal shafts are indeed longer than the Sport in order to attach the wheel center caps. The Sport portal shaft is 8255 and the Blazer/Bronco extended portal shaft is 8255A. |
Cool. Thank you for that info. That’s what I was thinking. Sent from my iPhone using Tapatalk |
Re: Trx4 sport 12mm hub extension problem You could also use shift hubs. They have a counter bored hole to make it so the axle you have will work. Counterbored= the hole where the axle comes through the hub is still thin but big enough in diameter to get a wrench in there to tighten the wheel nut. Most have either 3 or 6 bolts to hold the wheel on the hub. I run them on my comp crawler with 2.2 wheels and tires with only 3 bolts and have never had a problem. Good luck:mrgreen: |
