Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Traxxas Crawlers
Thread: TRX4 Sport Kit - How should I grease gears
Old 05-21-2020, 06:15 AM   #1
Default TRX4 Sport Kit - How should I grease gears
My son and I are assembling our first RC kit ever, the TRX 4 Sport. We are super noobs to the hobby so I have a super noob question. The instructions show "a drop of grease" on the gear (see picture).
https://imgur.com/a/EtEcvZ2
Should we be spreading that drop around the entire gear? It never says to so we haven't been. We are getting close to the end of our build but I don't want to damage the truck by not having greased the gears properly. Any help would be great.
kev971 is offline   Reply With Quote
Old 05-21-2020, 10:17 AM   #2
Default Re: TRX4 Sport Kit - How should I grease gears
Hear others views and advice first, but I am a slap the grease on, and plenty of it, type builder, too little is bad, I am unsure if too much is bad unless it gets onto something like a clutch...
But I was always taught never to skimp on the grease when I was servicing farm equipment, so have always been generous with it.
Element Sendero 1/10. Crawler/Trailer.
Scx24 crc. Crawler 1/24.
Wltoys a212. Shortcourse 1/24.
Wltoys k969. Drifty 1/28
Mr_Wolf_Is_Innocent is offline   Reply With Quote
Old 05-21-2020, 11:34 AM   #3
I use an old paintbrush to brush or "paint on" grease. Basically coat the gear face entirely with a thin coat of grease. Usually Red and tacky on metal gears, ceramic or any lighter grease on plastic. The Traxxas green grease is pretty decent for the kit build.
Overkill maybe, but I know all teeth are covered.
OSRC is offline   Reply With Quote
Old 05-21-2020, 11:55 AM   #4
Moderator
JatoTheRipper's Avatar
Good advice.
And if you don't have a paintbrush to dedicate to grease you can use a Q-tip or even a toothpick.
Old 05-22-2020, 07:34 AM   #5
Originally Posted by JatoTheRipper View Post
Good advice.
I use the finger method myself....
$uicide $hift is offline   Reply With Quote
Old 05-24-2020, 07:48 AM   #6
do you need to grease an out-of-the-box RTR?
splyn is offline   Reply With Quote
Old 05-24-2020, 10:18 PM   #7
Most of the newer RTR’s are greased “ok”. I always crack them open and check for sure. I don’t think you’ll be in a bad way if you don’t do it immediately but I for sure would after a couple, 3 packs through.
Lou
TK421 is offline   Reply With Quote
TRX4 Sport Kit - How should I grease gears - Similar Threads
TRX4 Sport kit or TRX 4 Crawler kit Question redpeppers Newbie General 13 09-15-2019 06:00 PM
TRX4 Sport body on TRX4 Crawler kit chassisc redpeppers Paint and Body 7 09-14-2019 12:59 AM
TRX4 Sport Kit or SCX10II Raw Builder's Kit? westerlycarrot9 General Crawlers 13 05-10-2019 10:34 PM
Trx4 sport with OD/UD GEARS garage-boo Newbie General 6 05-02-2019 09:34 AM
Trx4 kit or trx4 sport mebeknob Newbie General 10 09-26-2018 10:38 PM
