Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Traxxas Crawlers
Thread: To high gearing for a 12T crawlmaster?
Old 02-13-2020, 10:38 AM   #1
Default To high gearing for a 12T crawlmaster?
Crawlmaster 12T, 13T pinion, 46T spur, 2 speed. 4300g rig. Is it to high gearing? Should I drop it to 10T, or just drive in first gear when under load? Don't have time to test, and a longish trail is coming up this Sunday...
ChILd_ReBoRn is offline   Reply With Quote
Old 02-16-2020, 07:03 PM   #2
Default Re: To high gearing for a 12T crawlmaster?
The TRX-4 should always be driven in 1st gear under load in my opinion. 2nd gear only used when cruising from obstacle to obstacle...
Basically, I don't use 2nd gear when going uphill - only on flat ground or downhill.
I'm guessing that you have the 550-size Crawlmaster - keep the gearing as close to stock and I think you'll be fine.
durok is offline   Reply With Quote
To high gearing for a 12T crawlmaster? - Similar Threads
Crawlmaster Sport 550 12T 2S/3S/4S wheel speed video examples. LincolnofDeath Element RC 1/10 Enduro Trail Truck Sendero 2 12-16-2019 07:27 PM
Hw1080 with hh crawlmaster sport 550 12t on 3s? dirtman71 Electronics 8 11-25-2019 01:21 PM
HH 13t Crawlmaster brushed.....what gearing big_poppa49 Axial SCX-10 3 09-04-2017 07:13 PM
gearing with a titan 12t newbiecrawler5232 Axial Wraith 6 01-20-2012 03:12 PM
27t crawlmaster gearing sht50 Axial Wraith 2 11-11-2011 11:04 AM
