Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Traxxas Crawlers
Thread: Adjustable shock mounts from amazon
Old 10-04-2020, 03:47 PM   #1
Default Adjustable shock mounts from amazon
I assume these will NOT work on my trx4 Sport? I added inner fenders recently, and can't wrap my head around how they could work with the way the shocks mount to chassis on this truck?
R.C. means both;Remote control, and Rock Crawler.
23drumerboy is offline   Reply With Quote
Old 10-04-2020, 05:31 PM   #2
Default Re: Adjustable shock mounts from amazon
They can be used though. Once an adjustable shock mount is installed...you will have multiple holes on a flat surface. This can be bolted on to add additional angles. The large shock tension nut gets in the way ...rubbing the mount. This can give it the opening it needs to be fully adjustable. Or they could be bolted in front or behind the shock tower.
Jeff6x6 is offline   Reply With Quote
Old 10-04-2020, 06:02 PM   #3
This design...he bolted to the frame ...so I could see how it works bypassing the original shock tower. So the arrow would point up and the other end bolt to the frame at an angle twice. You would still need the tower to support the body posts.
Old 10-06-2020, 10:59 AM   #4
those are shock keys which would mount to your existing shock mounts allowing you more shock mounting positions.
I have used ones similar mounted to the chassis but not on my TRX4.
Unless you are mounting your steering servo on the axle and doing a 4 link front end you will need your front drive side shock mount to have a panhard bar mount.
MOguy is offline   Reply With Quote
Old 10-06-2020, 03:52 PM   #5
Link for the thread? I’d like to do something similar to my rig.
ScaleLifeNewbie is offline   Reply With Quote
Adjustable shock mounts from amazon - Similar Threads
Adjustable upper link mounts. corkysk8 Axial SCX-10 0 11-06-2013 05:45 PM
adjustable motor mounts lud98r Tamiya Clod Buster 5 12-12-2008 02:47 PM
adjustable motor mounts krawlinCJ Tamiya Clod Buster 6 04-15-2007 06:25 PM
