Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Traxxas Crawlers
Thread: TRX-4 build questions
Old 02-24-2021, 03:52 PM   #1
Default TRX-4 build questions
So, I'm planning on buying a TRX-4 Defender. I've read that the servo isn't good and that if I change the servo I should really get a BEC. These are the applicable things that I have sitting around already from my other RC cars and helicopters:
  • An old unused Overlander UBEC (4.8/6v selectable, 3A continuous, burst 5A)) which I'm figuring should do the trick temporarily if I select 6V.
  • Gens Ace 2s 1800mah hardcase lipo (Deans)
  • Gens Ace 32 2200mah lipo (Deans)
My (wife approved) limit is £600 and given the above, my plan at present is to buy the following (prices that I know that I can get them for are in brackets):
  • TRX-4 Defender (£517.50)
  • Savox 2210SG (£76.49)
  • Male Deans to female Traxxas TRX connector (£2.59)
  • Rx bypass cable (£6.99)
  • Metal servo horn (£7)
Total: ~£610
For the moment, I'll not be taking it through any water, so waterproofing of the UBEC and bypass cable are not a concern right now. The reason why I'm planning on getting the bypass cable is so that I can use the UBEC to power the steering servo alone, the ESC will still power the RX and diff-lock servos. That way, when I get a waterproof Castle BEC or something, I can up the servo voltage to 7.4V whilst keeping the RX and diff lock servos at 6V.
On the servo front, I'd rather stay with Savox since I've been really pleased with them and not had one fail on me yet.
Here are my questions:
  1. Does the above sound reasonable?
  2. Given my current budget, have I missed anything, or is there anything that you'd do differently with good reason?
  3. I'm really concerned about the low voltage detection on the XL-5 ESC, what is the cutoff voltage? Does it auto-detect 2s/3s and cut off appropriately? Would you suggest I use a separate low voltage alarm?
CaptainCalm is offline   Reply With Quote
Old 02-25-2021, 03:08 AM   #2
Default Re: TRX-4 build questions
This sounds like a solid plan. I personally would not by the adapter for the esc, I would chop the Traxxas connector off and solder on a dean. Maybe add an extra jst connector for the bec.
rob5059 is offline   Reply With Quote
Old 02-25-2021, 03:51 AM   #3
That's a fantastic idea. I think I'll do that.
Am I better getting a separate low voltage alarm?
Old 02-25-2021, 05:12 AM   #4
No need for that, the esc should be set to detect low voltage, just check the settings when you get it
stigno is offline   Reply With Quote
Old 02-25-2021, 05:26 AM   #5
Perfect, thank you.
This is my first crawler. I've just ordered everything and can't wait for it to arrive.
Old 02-25-2021, 08:07 AM   #6
I am sure you will have fun, welcome to this world
Old 02-26-2021, 02:45 AM   #7
Thanks
Tags
bec, lvd, servo, trx-4
TRX-4 build questions - Similar Threads
Noob with TRX-4 questions Scratchthejeepguy Traxxas Crawlers 15 01-18-2021 12:03 PM
New TRX-4 Sport & TRX-6 Intro & Questions TRX-4-Baker Traxxas TRX-4 11 08-18-2020 11:49 PM
TRX-6 Light Module Questions hibbs Electronics 2 04-19-2020 10:33 AM
Thinking about a TRX-4: a couple of questions Foghat Newbie General 35 01-28-2020 06:07 AM
few questions on the EVX2 ESC by TRX SwampDawg Electronics 2 03-03-2014 12:45 PM
