07-12-2021, 12:39 PM | #1 |
Newbie Join Date: Jun 2021 Location: Carson City
| TRX4 kingpin slop
I have a TRX4 new out of the box, noticed front wheel slop. Is it normal for the kingpin bushing to be loose in the housing? I realize the kingpin is just a screw and not a 'pin' and it is loose in the bushing, but the bushing in the housing? thanks |
07-12-2021, 01:42 PM | #2 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
| Re: TRX4 kingpin slop
Hmmm, I didn't notice any excessive slop on mine, even after many hours in abrasive dust. Only up-down play.
07-12-2021, 08:00 PM | #3 | |
Quarry Creeper Join Date: Jul 2020 Location: US
| Re: TRX4 kingpin slop Quote:
Also i found The factory bushings for the kingpins are like a soft brass or similar material so they deform easily and if they're not the perfect diameter they need to be from the get-go... You already have initial slop without even haven't been on the road I know this because I tried using some red cat streetcar bushings as a temporary fix and they were just sloppy. No matter what I did. So make sure the size of them is appropriate with a pair of calipers or similar. Also, u will see nothing but maybe the few shims i put on either side of bushing (they have no "collar")....i also feel strongly that the play comes from beat up end links, and servo slop/factory looseness. The angled rod end kit i added to my HC center steering link, kinda adds a hint of toe out up front, hut applies more outward pressure against bushings so what play/"tolerance" MAY exist, is minimized. Read-Up! Mod-On! Crawl EXCESSIVELY! | |
07-12-2021, 08:01 PM | #4 | |
07-12-2021, 08:34 PM | #5 |
You can shim the vertical slop with 5mm I'd shims between the knuckle and c-hubs, trying to center the inner axle in its opening in the housing. Locked up offers steel c-hubs and some brass bushings that are very snugly fitted and will wear will. Theoretically down the road the softer, inexpensive, bushing wears, and the steel chub will be reusable. |
TRX4 kingpin slop - Similar Threads | ||||
******Give away! DLUX - No Slop Kingpin Bushings ****** | Erik D_lux | Axial Wraith | 70 | 10-04-2012 07:59 PM |
******Give away! DLUX - No Slop Kingpin Bushings ****** | Erik D_lux | Axial XR10 | 96 | 10-03-2012 10:11 PM |
AX-10 Kingpin Bushings | bondt | Newbie General | 6 | 02-19-2009 08:10 AM |
