11-29-2021, 10:05 AM | #1 |
Newbie Join Date: Oct 2021 Location: San Francisco
| TRX4 Weight, Battery, and Run Time
Just curious what everyone is running... My TRX4 sport kit weighs 9 lbs. I use a 4300mah battery up front with a HH Crawlmaster sport 12T. 45/13 spur-pinion. Last night I got about 1.5 hrs on the pack before it got to 3.8v per cell |
11-30-2021, 08:09 AM | #2 | |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
| Re: TRX4 Weight, Battery, and Run Time Quote:
Sent from my SM-G991U using Tapatalk | |
02-26-2022, 08:44 AM | #3 |
Newbie Join Date: Dec 2021 Location: Coral Springs
What battery do you use?
02-26-2022, 08:47 AM | #4 |
What battery do you use MAX D?
02-26-2022, 02:15 PM | #5 |
Quarry Creeper Join Date: Jan 2021 Location: in the Canyon
TRX-4 Sport + 2-speed, weighs about 7.5lbs with a Creep and some brass up front. 14/45 gearing with 1080 + Tekin HD 35T 540. Usually 45-50 minutes out of a 3S 1500mah (Zeee or CNHL) pack. It's more than enough as those 1500s weigh less than 4oz, and you can easily fit two of them in a pocket. TRX-4 (formerly a Defender) now with a JConcepts K10 shell. North of 9lbs, HW AXE 550 R2 3300Kv geared 12/45, definitely under an hour on a GensAce 4300 Adventure pack. That's a whole lotta motor to put on something with a 2-speed. If I had it to do again, it would be WAY lower Kv. |
02-26-2022, 04:05 PM | #6 |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
TRX4 Sport(kit). Single speed tranny. Chassis has all excess weight stripped. Not sure on weight but it’s relatively light. Maybe around 5-6Lbs? Stock body without rack and bumpers, No brass, and a HW fusion on stock 39/17 gearing. I run a 3500mah 2S shorty up front and get about 1.5-2hrs depending on my driving that day.
03-01-2022, 10:16 PM | #7 |
Quarry Creeper Join Date: Dec 2019 Location: California
Not a TRX4, but a TRX6 TRX6, +2speed +Lockers Mostly stock chassis with heavy body cosmetics (custom bed, bumpers, lights, metal roof rack etc) No definite weight but most likely over 10 lbs. HW AXE 2850Kv R2, 11/45 gearing + MKS HBL 550 + winch (mostly unused) + Light kit SMC 5200mah hardcase 3-4 hours of crawling at one large location, A long while doing rounds on my relatively small backyard course. Trail/hiking 1.5 hours or so. Usually a fully charged 5000mah pack lasts me a week crawling around in my home course. |
12-07-2022, 03:49 PM | #8 |
Newbie Join Date: Nov 2022 Location: Europe
My stock TRX4 Defender with a Li-Ion 6800mAh 2S in Trail Mode gives me 55 minutes of hiking/trails mixed in with terrain (like 4x4 tracks in sand/mud/snow) at this time of year.
12-08-2022, 12:24 PM | #9 | |
Quarry Creeper Join Date: Nov 2020 Location: Greece
55 minutes out of a 6800mAh battery sounds too little. Have you checked a different battery? | |
12-21-2022, 07:56 AM | #10 | |
It's when a cell won't stay above 2.8V at no load that it's drained. The problem for me is that the ESC will cut the power already at 3.3V/cell | |
12-21-2022, 09:17 AM | #11 |
Most sites indicate that the usable voltage range for a standard LiPo battery cell is 3.2v to 4.2v. Any lower than 3.2v and the battery might be permanently damaged... Your results may vary, but I stick in the safe range because I typically carry at least one spare pack to throw into the vehicle per crawl session. |
TRX4 Weight, Battery, and Run Time - Similar Threads | ||||
Run Time vs Battery mha and Bed Battery | Greatscott | RC4WD Trail Finder 2 | 4 | 09-18-2017 09:25 PM |
Battery run time? | Tinbum | General Crawlers | 3 | 07-19-2014 04:06 PM |
battery run time losi battery | perez62682 | Team Losi Comp Crawler | 4 | 03-14-2010 08:22 PM |
Battery Run Time | JasonA | General Crawlers | 2 | 11-14-2006 10:29 AM |
