04-29-2022, 12:15 PM | #1 |
Rock Crawler Join Date: Mar 2012 Location: UK
| CC’s Summit I’ve built the diffs with alloy cups, acer bearings and steel internal gears Also fitted a LEM dog carrier HH SHV800 Servo And all powered by a Castle MMX Motor wise I’m using the stock 775, but can quickly swap over to a HH Puller Pro 4274 Smooth 1900 when i want using a Castle Bluetooth link to quickly change the settings |
04-29-2022, 12:18 PM | #2 |
| Re: CC’s Summit |
04-29-2022, 12:25 PM | #3 |
| Re: CC’s Summit
Beefed up the steering with alloy servo saver arm, it started off as a double, but I chopped it into a single, I only use the arm part, I don’t like alloy on alloy for servo savers, always best to have one part plastic so the action stays consistent Ignore the servo, I was using the Shifts before I swapped over the esc and was powering it direct off one of the lipos Also I made up a tougher drag link out of some m4 SSD rod ends and team it all up with a alloy servo arm Last edited by Curb Crawler; 04-29-2022 at 12:41 PM. |
04-29-2022, 12:48 PM | #4 |
RCC Addict Join Date: Aug 2008 Location: Paulina
| Re: CC’s Summit
Nice job. Why not just leave the Puller Pro motor in there?
04-29-2022, 01:17 PM | #5 |
| Re: CC’s Summit
I would rather not get it wet, it’s the most expensive motor I’ve ever bought lol, but as it’s nearly summer time here it will be staying in for now
04-29-2022, 08:35 PM | #6 | |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
| Re: CC’s Summit Quote:
The puller pro should be waterproof, so I would imagine it’s fine. I’ve gotten my HW Fusion wet on more than one occasion without issue. Now I would be worried about the ESC… __________________ Amain Addict | |
04-30-2022, 12:31 PM | #7 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
| Re: CC’s Summit
I always wanted a Summit ever since I drove a buddies 9 years ago. Sweet truck. Sent from my SM-G991U using Tapatalk |
05-04-2022, 09:11 AM | #8 |
| Re: CC’s Summit |
05-04-2022, 02:13 PM | #9 |
Rock Crawler Join Date: Nov 2014 Location: North to Alaska - go north, the rush is on....
| Re: CC’s Summit
Nice!!! all of my RR products have been top notch. This is one of those rigs I have wanted for a long time, but just never pulled the trigger on. |
05-06-2022, 10:59 AM | #10 |
| Re: CC’s Summit
The stock slipper is fine with the stock 775 motor, but with brushless I couldn’t get any consistent settings, one minute it was set fine and then the next it would slip like crazy, that was with even thread locking the adjustment lock nut. The RR holds it setting perfect so far.
07-06-2022, 10:57 AM | #11 |
| Re: CC’s Summit |
CC’s Summit - Similar Threads | ||||
Traxxas Summit/Slayer (Summit Lt) Trail Truck | SummitOner | Traxxas Crawlers | 21 | 09-20-2021 11:38 AM |
my Summit LT.... Slummit...Slayer/Summit:) | Chainsaw10 | Traxxas Crawlers | 65 | 05-07-2015 11:29 PM |
