05-10-2007, 08:34 AM | #1 |
Newbie Join Date: Apr 2007 Location: hopkinsville
| would like to build ive been thinking on building an emaxx crawler. i have a set of these for my emaxx, been thinking on building a crawler with these these bulkheads lets you run 1/8 scale buggy gears in your emaxx with the same size bulk heads questions want to run a solid axle dont like the looks of the locked out a arms but having problems figering out how to mount the axle tubes to these open to any suggestions except using the normal a arms for the maxx |
05-10-2007, 12:00 PM | #2 |
Quarry Creeper Join Date: Jul 2005 Location: Oran, MO
Yeah, make some axle tubes with a flanges on both ends and drill and counter sink some screws from the inside of the housings and bolt the flanges to them. You will have to use cvds more than likely due to the size of the axles. And they will have to be stock maxx width either narrow or wide maxx. You might be able to pick up some cvds for a old narrow tmaxx cheap since no one runs those anymore. Do a search for my "prototype pvc axles". You can get the idea from that. You can use steel or aluminum or copper tubing if you want. |
05-17-2007, 08:00 AM | #3 |
Rock Crawler Join Date: Apr 2007 Location: LaSalle
any updates ??? i ant to see how this project works out
05-18-2007, 04:32 AM | #4 |
no updates still getting the gears to go inside. job takes alot of time out. so it will be a really slow build
05-18-2007, 07:42 AM | #5 |
Quarry Creeper Join Date: Nov 2005 Location: Australia
care to share where those bulkheads came from and how much they cost?
05-18-2007, 04:48 PM | #6 | |
RCC Addict Join Date: Sep 2005 Location: Behind the torch!
