06-10-2007, 01:19 PM | #1 |
Quarry Creeper Join Date: Feb 2007 Location: East Aurora
| 2.2 maxx?
has anyone ever built a 2.2 maxx?because i am thinking abiout doing it because i have the extra materials and it would be cheaper then a super and i am a fan of the 2.2's!
06-10-2007, 01:35 PM | #2 |
Rock Stacker Join Date: Mar 2007 Location: Romeo
do the 2.2 rims fit over the knuckles? because i thought about making it 2.2 seeing as I have a set of M2K's just chillin over here..
06-10-2007, 01:58 PM | #3 |
hmm idk im pretty sure all that u would need is a diff adapter for the 2.2 size wheels
06-10-2007, 02:00 PM | #4 | |
Rock Crawler Join Date: Apr 2007 Location: LaSalle
you will prolly have to make some adapters or get a very ofset rim for them to fit onto the maxx axles its totally possible but just y not make a super instead or get a tlt txt somthing along those lines to build your 2.2 | |
06-10-2007, 02:54 PM | #5 |
well i have a nice tlt tuber and i love it and where i live most people have 2.2's so i want a second one and i have a tmaxx laying around for my dad to use
06-10-2007, 03:48 PM | #6 |
you could try it but you would have to get some adapters or very of set rims then change the hex on the maxx axles to match up with the 2.2 wheel size hex
06-10-2007, 05:41 PM | #7 |
yea i know what ur saying but i am going to do it this week so i will post some pics probably friday
06-10-2007, 05:58 PM | #8 |
ok cool keep us updated
06-10-2007, 07:26 PM | #9 |
Pebble Pounder Join Date: Jul 2005 Location: Greece
If you are not building this for a comp that the rules require 2.2 rims try the 2.9 rims. The ones that are used on the new Rustler and Pede fit over the stock maxx knuckles. You will only need to modify the hex to fit a smaller size. IMEX makes a good selection of tires. I prefer the Traxxas rear stock Electric Rustler rims. They allow the nut to sit flush on the surface. Some of the IMEX rims make it hard to use the proper nut for the maxx axles.
06-10-2007, 07:37 PM | #10 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
yes a few people have built 2.2's..... just use a 12mm hex and be done with it.. easy enough I did that on mine and never had a problem.. |
06-10-2007, 08:17 PM | #11 |
Quarry Creeper Join Date: Aug 2006 Location: NORTH TEXAS
yes the hubs will work if you use the the right offset wheel. or make some totaly diffrent ones. some maxx diffs, wheely king steering blocks, jato shafts, pvc pipe and epoxy . these work great |
06-11-2007, 09:03 AM | #12 |
not bad ive deen a few people do that with pvc pipe how well does it hold up??
06-11-2007, 08:05 PM | #13 |
Rock Crawler Join Date: Jun 2007 Location: oVER ThErE
I built one before I just grinded the knuckle down alittle. It worked fine...
06-11-2007, 09:04 PM | #14 | |
this is a thread i posted about the first ones. lots of good pics. 2.2 MAX RIG with PVC AXLES!! | |
06-12-2007, 03:39 PM | #15 |
2.2's fit just fine... it's just about wheel choice and hex building. |
06-13-2007, 11:07 AM | #16 |
wow man that is a fine ride toyo, can u post up some more pics or maybe send me a link to ur write up if there is one?
06-13-2007, 02:07 PM | #17 | |
Thanks... that's what I had back in 2005. Most of it should be here on RCC. You'll just have to search my username in the Maxx section to dig up the dirt on my past rig. | |
06-13-2007, 04:17 PM | #18 |
okok thanks man, well i was away i started experimenting with some things and i made an axel using the two diff holders inbetween two peices of metal with rustler knuckels, i will have pics up later
06-13-2007, 06:27 PM | #19 |
To fit the 2.2 wheels to my Maxx knuckles all I did was take the 14mm hexes that are about double the width as stock Maxx hexes and cut them down to 12mm.
