07-03-2007, 01:35 PM | #1 |
Rock Crawler Join Date: Jun 2007 Location: Great Britain
| Emaxx Tranny Keep It Two Speed or Go Single
Im going to biuld my self a crawler useing a Emaxx tranny I have and was wondering what you guys do with them. The land that I will probably be using it on isnt all rocks so I though of keeping the two speed for a bit more wheel speed between rocks. But first I thought I would ask what you guys do about the two speed. Thanks Tupers |
07-03-2007, 02:12 PM | #2 |
Rock Crawler Join Date: Jun 2006 Location: Sinking Spring
I think that you should go with a single speed. You can gear it to have enough wheel speed and also to keep it slow in the rocks. The change in the 2 speeds isn't very much anyway. So I say go single speed. Krystopher |
07-03-2007, 03:19 PM | #3 |
Quarry Creeper Join Date: Jan 2006 Location: ---EAST--TN---
It would be cool to be able to shift to 2nd and nail it when you wanted some more speed. but... the problem with keeping the 2 speeds is there is a TON of slop. Way to much slop for a crawler in my opinion. If you let off the throttle on an uphill climb, it will roll back about a foot before all the gears get lined up and engaged again. Id keep it locked into one gear or another. Its a stout tranny. I run one, but mines locked into gear. |
07-03-2007, 03:28 PM | #4 |
Rock Crawler Join Date: Jul 2005 Location: Rathdrum, ID USA
Single speed is all you need. Check out GorrillaMaxx for a clean single speed conversion and a single motor mount... http://www.gorillamaxx.com/ |
07-03-2007, 06:39 PM | #5 | |
Funny I have three rigs with e-maxx trannies in them and once you stop on a uphill they dont roll back. They do however have about 2-4 inches of roll on a level surface, and that's depending on your tire size. | |
07-03-2007, 09:31 PM | #6 | |
Quarry Creeper Join Date: Jan 2007 Location: Ontario, Canada
07-04-2007, 09:18 AM | #7 |
Newbie Join Date: Apr 2007 Location: arp
| roll down
i still have the two speed tranny i like the idea or a little burst of speed . I to have the freewheelen under no power i just set the trim up or down bepending on going up or down hill ,
07-04-2007, 03:03 PM | #8 |
Thanks for all the help guys. I've decided that Im going to keep it two speed for the moment,but lock it in one gear useing a colet on the gear change shaft. That way I can test it in both gears to see wich one is better for my kind of terrain. Thanks again for all the help. Hopfully I will be able to do a biuld thread once I have a few other things done and out the way. Tupers |
