07-18-2007, 08:37 PM | #1 |
Rock Crawler Join Date: Apr 2007 Location: portland
| weak steering
i am using threaded rod (im not sure of the thickness but it is pretty thick, i had to drill out my traxxas rod ends to make them fit) for my steering link and it is easy to bend. i can grab both tires in my hands and turn one tire about 45 degrees with ease. i tried taking another piece of threaded rod and brazing it to the first one and now both of them still flex. Help!!!
07-19-2007, 10:28 AM | #2 |
Pebble Pounder Join Date: Sep 2006 Location: hamilton
you can try and put aluminum rod over the threaded rod and that might help a bit
07-19-2007, 10:36 AM | #3 |
Newbie Join Date: May 2007 Location: Russellville, AR
3/8 Brake line works pretty well if you dont put too much of a bend to it and it cheap |
07-19-2007, 01:08 PM | #4 | |
There is a sticky for how to building a crawler... in that sticky you'll find tons of info for building your crawler, that is if you want to do it on your own. Quote:
RCCRAWLER tips, cheap tricks / parts guide. | |
07-24-2007, 03:19 PM | #5 |
Rock Crawler Join Date: Jun 2007 Location: oVER ThErE
Yes an alumunim overlay covering will help.
