Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: 72 tooth spur question
Old 05-26-2005, 06:08 PM   #1
Default 72 tooth spur question
I just got my 72 tooth spur. Will I run into any issues installing it? Also will I still have use of 1st and 2nd gear? This will be the first time I get into the emaxx transmission.
Thanks
cuban b is offline   Reply With Quote
Old 05-26-2005, 06:59 PM   #2
Changing The Spur Gear Has Nothing To Do With The Internal Functions Of The Transmission. No You Will Still Be Able To Use First And Second Gears. Just Remember To Replace The Friction Pegs In The New Spur And Tighten It Until You Can Tighten It Down Anymore.
Hope That Helps.
NATE
Xtremekrawler8 is offline   Reply With Quote
