Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: Too much torque twist
Old 06-08-2005, 12:19 PM   #1
Location: World -> Europe -> Italy -> Umbria -> Perugia -> Assisi -> Petrignano di Assisi
Default Too much torque twist
Hi,
My crawler suffers of torque twist, how can i resolve the problem??? I can resolve it with a more dense suspension oil???
Garrett is offline   Reply With Quote
Old 06-08-2005, 01:39 PM   #2
2006 2.2 National Champ
BENDER's Avatar
Originally Posted by Garrett
Hi,
Do you have any pics of your set-up? It's tough to tell without more details from you.
Thicker oil can help, among other things. Link and shock placement play a big roll in controlling torque twist.
BENDER is online now   Reply With Quote
Old 06-08-2005, 02:14 PM   #3
This is my old setup:
This is my new setup:
and other photo here:
http://garrett.altervista.org/magazz.../Foto(433).jpg
http://garrett.altervista.org/magazz.../Foto(434).jpg
http://garrett.altervista.org/magazz.../Foto(435).jpg
http://garrett.altervista.org/magazz.../Foto(436).jpg
I have moved front shocks more up from the old setup, and i have to do this on the rear shocks too. But i think that it isn't sufficient to eliminate the torque twist. I think that this shocks are too soft...
Old 06-08-2005, 02:25 PM   #4
BENDER's Avatar
I would drop the ride height, your center of gravity is too high. Lower it until the upper links are flat or parallel to the ground. Your lower shock mounts should be moved off the links and re-located to centerline of your axles. Try to mount the top of your shocks, after you move lowers, so the shocks sit almost vertical. If you get some stiffer springs and thicker oil for your shocks that will also help too.
There are some pics of my TXT here, it's not a Maxx but the same principles apply.
http://www.rccrawlermedia.com/rcc-gallery/album01
Old 06-08-2005, 05:16 PM   #5
Wink
Thank you very much for your advice!!
Old 07-24-2005, 07:15 PM   #6
Deffinently lower the ride heigth so you can get a lower COG, and mount the lower shocks to the axles, that should solve the problem.
mtnbkerman is offline   Reply With Quote
Old 07-24-2005, 07:37 PM   #7
I agree with everyone here, lower it and get some COG Back... but those tires should give you the advantange over anything... Nice lookin rig BTW
Nova is offline   Reply With Quote
