| | #1 |
| Quarry Creeper Join Date: Mar 2005 Location: Pleasant Grove
| I break a yoke or stub shaft every time I go crawling with the e-maxx. I was looking at cvds and it looks like I could get a set of clod axles for the same price. What should I do? opinions? |
| Sponsored Links | |
| | #2 |
| TEAM MODERATOR ![]() Join Date: May 2004 Location: Tennessee
| But then you be stuck with Clod axles. You'd be going the wrong direction IMHO.Get the CVD's,build solid axles and you'll be set CLOD AXLES Last edited by Reflection; 06-11-2005 at 01:45 AM. |
| | #3 |
| Pebble Pounder Join Date: Apr 2005 Location: World -> Europe -> Italy -> Umbria -> Perugia -> Assisi -> Petrignano di Assisi
| Cvd |
| | #4 |
| Colt Python/SR9c ![]() Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| only MIP cvds.... I have never broke a MIP cvd, only have broke the other cheap sets |
| | #5 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| convert it to revo shafts and knuckles, it will make it wider. . i have broken the cheaper cvd's, i forget the brand. x-factor i think. probably same as dynamite. |
| | #6 |
| Newbie Join Date: Mar 2005 Location: hazle green
| Will a revo axle fit an emaxx gearbox and knuckles ? |
| | #7 |
| you want emaxx diff and bulkhead and arms; the axle shafts, knuckles, and outputs from the revo bolt up for a supurbly stout fit. i had to shave my upper RPM arm for proper clearance. |
| | #8 |
| will revo axles fit emaxx knuckles ? I might use them on my new buggy if they will fit. you can buy a set of them cheaper then the cvds |
| | #9 |
| 200th engineering ![]() Join Date: Apr 2004 Location: Not where I belong.
| i had the same problem with my maxx, so i shortened a female end so its a half inch or so long (i never measured, just hacked them off) and glued a piece of male shaft into it, then inserted the oher female shaft, they are stronger than stock, and if you are like me, you prolly have some pieces of shafts laying around to use up P.S., please, nobody take this like a sick little perv and trying to make a joke out of it, it will just prove you are an idiot |
| | #10 |
| well i am an idiot and can think of a bunch of things, but won't since we need to keep it "tech" related people also drill out the middle of the plastic axles and shove dowel pins down the middle of them and glue them in place. That way it takes up the hollow space with something solid. I have never tried it, but everyone who has seems to like them and have had no problems |
| Thread Tools | |
| Display Modes | |
