Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: Newb E-Maxx questions
Old 06-29-2005, 07:45 PM   #1
Default Newb E-Maxx questions
I am going to build an entry level crawler out of my e-maxx. I am not looking to go as far as custom chassis except a tube roll cage. I already order a spool for the front differential, beadlocks, swamp dawg tires, 10 tooth pinion and I am looking for a 44 tooth spur gear. I am going to buy a 55 turn lathe motor if I can find one. Is there anything else I would need to buy to make my e-maxx crawl better? What shocks are the best for crawling?
Thanks in advance for the help.
coolkide is offline   Reply With Quote
Old 06-29-2005, 08:21 PM   #2
Are you planning on locking out the ifs and irs in to a solid axle and four linking it?
ttrmike is offline   Reply With Quote
Old 06-29-2005, 08:31 PM   #3
Check here for the motor;
http://www.integy.com/
They are out of stock at this time, but.......
The maxx shocks work really good. Do a search in this section to find more specific information on the maxx.
Jeepjunky is offline   Reply With Quote
Old 06-29-2005, 08:37 PM   #4
I am just gonna replace the front diff. spider gears with the spool. thanks for the help.
Old 06-29-2005, 08:38 PM   #5
Colt Python/SR9c
TwistedCreations's Avatar
why in the world are you only running a 44tooth spur gear? :?
stock is 66 tooth. I would at least run a 72 spur gear.. 44 would defeat the purpose of a smaller pinion gear and lathe motor
also... if you lock only one, you will raise havock with your driveline.. so lock both.. it wont matter anyway cause you will need a stronger steering servo for the front
TwistedCreations is offline   Reply With Quote
Old 06-29-2005, 09:47 PM   #6
I have an upgrade steering servo. what would I need for 4WS.
