Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: Build-up: trail maxx
Old 07-02-2005, 07:54 PM   #1
Default starting chassis
i am going to make my chassis out of 2 plates of aluminum. here is a template of what it will be like, what do you think?
do you think the chassis is a good size or shoud it be samller or bigger? on both sides i will bolt a maxx chassis brace, i will have to do some trimming on the motor mount. i know i will have to space the chassis out on one side to fit the motor but i'll figure that out.
so will this work? please tell me what you think
thanks
colin
Maxx4life is offline   Reply With Quote
Old 07-02-2005, 09:44 PM   #2
It should be smaller, a lot smaller. Don't be afraid to hang things off of the chassis like the ESC reciever and battery. You should make the chassis as long as the braces you have pictured, then mount the RX and ESC either behind of in front of the tranny. Since maxx axles are so huge, you can mount your battery on the front axle.
CustomCrawler is offline   Reply With Quote
Old 07-02-2005, 10:33 PM   #3
wow, that is a lot smaller, i'll make another template and post a pic. i'm not sure about mounting the batt on the front axel, i don't do to much hill climbing, and what would you suggest the links be? just a rought estimate as a starting point.
thanks
colin
Old 07-03-2005, 12:16 AM   #4
link length is hard to say. you would have to make mounts on the axles and decide on where they will mount to the chassis.
i was the original creator of the "chassis brace" chassis idea. so i had it all planned out. of course my idea was meant for a tlt. but we adapted it to a maxx. however eclipse no longer intends on going that route with his maxx.
fuzzhead is offline   Reply With Quote
Old 07-03-2005, 10:51 AM   #5
ok, here is a new template
is this a good size or is it still to big?
thanks
colin
Old 07-03-2005, 06:44 PM   #6
well i built some suspention lockouts
and here is the bulkhead support/ top link mounts
all i have to do is make another top link mount for the rear then i will start on my chassis. so is the new template the right size?
colin
Old 07-03-2005, 07:09 PM   #7
Much better! Instead of offsetting the plates, just make a cut out for the tranny to sit in. That way your link mounts are the same for both sides of the chassis. check out some other maxx on this site and compare them to what you want to do for your link sizes.
Jeepjunky is offline   Reply With Quote
Old 07-03-2005, 08:03 PM   #8
yea, i was just thinking that, it will work a lot better and the chassis will only be about 3" wide. i am doing more searching as we speak.
i make the rear top link mounts, so now i'm going to cut out the chassis plates, order rod ends, buy some threaded rod and some thick aluminum tubes for the links and chassis supports. i'll post some pics of the chassis when they are cut out.
thanks for the help and any recommendations would be great
colin
can somebody link me what a good strong cheap rod end, will the traxxas maxx rod ends work?
Old 07-03-2005, 09:33 PM   #9
hey colin, you should try and get this all done by the time you come over on the 15th or whenever. there are some pretty good crawling spots out where we used to play paintball. the chassis design looks good. you should put the receiver and evx on the side plates or in between them at the back. good luck. and if you need i can help you on friday or whenever we hang out this week.
peace
harris
Harris is offline   Reply With Quote
Old 07-03-2005, 10:06 PM   #10
yea, harris you can come over thursday and i will get my car back together so we can to to my new crawling spot.
so is 6/32 threaded rod and 1/4" tubing make good links? i am planning on using stock maxx rod ends.
colin
Old 07-04-2005, 02:10 PM   #11
here are my chassis plates
what do you think?
colin
Old 07-04-2005, 04:14 PM   #12
here is my new shock tower thing, works a lot better.
colin
Old 07-04-2005, 07:25 PM   #13
Default Build-up: trail maxx
well, i started a post about how to make the chassis but now i an building it. here is the older post here
so i made the chassis plates, locked out the independend suspention, locked the diffs.
here is how i am planning on mounting the shocks
(looking at chassis from 3 feet away)
(inside view of chassis plate)
so will the shock mounts work?
the chassis will be about 2 3/8" wide (the stock width of the chassis braces on a maxx truck). i am planning on mounting the battery on the rear axel because there will be no rear stear so i have more room. it will be 15"-16" wheel base and about 4" under chassis clearance. i am using stock maxx rod ends with 6-32 threaded rod with 1/4" tubing over it.
all hints, tips, suggestions, dislikes are welcome
thanks
colin
Old 07-04-2005, 07:27 PM   #14
Colt Python/SR9c
TwistedCreations's Avatar
Merged both your threads. No reason to make a new post about the same truck
TwistedCreations is offline   Reply With Quote
Old 07-06-2005, 12:49 PM   #15
update:
chassis with gear box
battery mount
lower link mount and shock mount
what do you think?
colin
Old 07-06-2005, 08:15 PM   #16
servo mount parts
servo mount with servo
chassis with rear hooked up
colin
Old 07-06-2005, 08:36 PM   #17
The only thing I can see wrong with your build is that everything looks so FRAGILE. The weight of the axles and tires alone seem to be more than what that chassis and links are able to handle. :?
Esteban86K5 is offline   Reply With Quote
Old 07-06-2005, 08:47 PM   #18
everything that you see that is threaded rod will have 1/4" tubing over it. the chassis will have like 6 braces in it and the tranny will tie everything together.
harris
Old 07-06-2005, 08:49 PM   #19
Should be fine. Just in it's current stage it looks awefully thin.
Old 07-06-2005, 09:15 PM   #20
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
maxx axles are really heavy. i had trouble with my first 3 link because i was used to building for clods and tlt's. other than that you have a really good start on it. your servo mounts might flex some though, you might want to cut some more with thicker stock.
JohnRobHolmes is offline   Reply With Quote
