Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: 4ws and locked diffs
Old 07-12-2005, 04:12 PM   #1
Default 4ws and locked diffs
Does anybody have any problems with both front and rear diffs being locked and 4ws. I'm just about ready to buy everything up that I will need for this project, and was wondering how they handle.
minty428 is offline   Reply With Quote
Old 07-12-2005, 05:57 PM   #2
Colt Python/SR9c
TwistedCreations's Avatar
yes, everyone has problems with that setup. that is why noone runs their trucks like that
TwistedCreations is offline   Reply With Quote
Old 07-12-2005, 09:53 PM   #3
Look at the trucks in the archives, almost everyone there has the same setup you are asking about, it works just fine. Next time you should do a search to see what threads come up, that way the mediators don't get pissy. Ok, who took my smilies, I can't flipoff if no smilies!
Jeepjunky is offline   Reply With Quote
Old 07-13-2005, 01:10 AM   #4
I got around this problem by using a thick mastic (gooey compound) in the diffs rather than locking them.
Still allows the diffs to work but stiffens them up so that they work like a really tight LSD and you can still get the traction to the ground.
MudCow is offline   Reply With Quote
Old 07-13-2005, 05:43 AM   #5
Colt Python/SR9c
I didn't get pissy,just gave a smartass answer to a " use common sense" question
as for the smilies, check your settings. go into user/cp, edit options,scroll to the bottom and change it from basic to standard and see if that works for ya
Old 07-13-2005, 12:48 PM   #6
I was just wondering because with full scale vehicles and it's in 4wd and you turn hard you almost get a shutter like crabbing and wondered if with 4wd it would make it worse. **** so many of you here answer with smartass questions. Maybe you did a lot of tweaking when yuo put on 4ws how do I know I've searched but no one ever really said they had to do alot. I'm just tryn to learn and dumbass people open their mouth and say dumbass things, geez.
THANK YOU MUDCOW!!!
SERIOUSLY.
That is what I wanted to know.
Old 07-13-2005, 04:00 PM   #7
I wasn't being a smartazz, I answered your question as you asked. I only suggested you look around at what others are doing to their trucks. The thing is so light that you wouldn't notice any problems like you do on a full scale truck. Yes, it does sucks when you do a search and it comes up with a bunch of BS and no answer. If you are still worried about your diffs causing problems with the steering, try some 200,000 wt silicone diff lube that they use in the /18th scale buggies. That might be a cheap way to see if you want to be totally locked or not.
Old 07-14-2005, 12:57 PM   #8
Well got both diffs locked and secured lastnight but haven't had a chance to run it yet... still in a few pieces lol.
