Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: Stock Maxx
Old 07-12-2005, 11:53 PM   #1
Dave's not here!!!
Greatscott's Avatar
Question Stock Maxx
Just wondering if anyone uses the stock chassis and arms (not locked)? If so, what do you run for springs/shocks?
Greatscott is offline   Reply With Quote
Old 07-13-2005, 12:01 AM   #2
u mean for crawling...not a whole lot of people use indipendent axles cuz uu get nowhere with them and for crawling with stock chassis, u must be joking.
Eclipse is offline   Reply With Quote
Old 07-13-2005, 12:08 PM   #3
Dave's not here!!!
Greatscott's Avatar
Nope, not joking. I have a specific application in mind that uses stock arms and chassis, but I wanted to find out the best stock/sping set up to give enough support to hold up the chassis, but also give maximum (as much as possible) tire contact.
Thanks
Old 07-13-2005, 12:23 PM   #4
2006 2.2 National Champ
BENDER's Avatar
I've got a big heavy Maxx that is still independent, running the EVX with dual batteries/motors. I run Trinity's "black" springs for the Maxx trucks, they're stiff enough that you'll only need to run 4 shocks. I have them on some Powerline Racing threaded aluminum shocks, filled with 80w oil. I still get full flex without much sagging and I could always pre-load the shocks more if needed.
BENDER is offline   Reply With Quote
