| | #1 |
| Quarry Creeper Join Date: Feb 2004 Location: Mountain State!
| I have a question about the maxx? When you convert a maxx to a solid axle does it also have the chassis twist that the txt has?????? |
| Sponsored Links | |
| | #2 |
| Did I ask a stupid question? Should I already know this or what!!! How come out of all 60 some hits not one person has thrown me a tid bit of information??????? |
| | #3 |
| It's a setup! ![]() ![]() ![]() Join Date: Jan 2004 Location: The Crawler State
| If built properly it will not get the lean when you hit the throttle. Mine does not do it at all. Dirk's txt-1 has been reconfigured and his doesn't get the lean either. |
| | #4 |
| Quarry Creeper Join Date: Jan 2004 Location: Ontario, Canada
| Yes it shouldn't give a lot of lean if not any. jugg_crawler |
| | #5 |
| The Wheels Keep Turning ![]() Join Date: Jan 2004 Location: Phoenix, Arizona
| how do you guys get rid of the torque lift on the axles? if the drive shaft that supplies power to the solid axle is applied along the line of the links or any angle less than perpendicular to the links, the drive shaft will create a torque or moment on the solid axle that will push one side down and lift one side up. |
| | #6 |
| Thank you for the info guys!!!!!!!! |
| Thread Tools | |
| Display Modes | |
