| | #1 |
| Newbie Join Date: Mar 2004 Location: DYER,IN
| i am lookin to replace the stock motors on my emaxx, what do you guys recommend?? i was reading somewhere online of the best motors to use, but i cant remember where it was. also is there a good place online to order emaxx parts? i am definately in need of some pinion gears and some spools. thanks |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Feb 2004 Location: Astoria, Oregon
| The titans work fine, unless your truck weighs over 20 pounds I would think the titans would get the job done. |
| | #3 |
| Rock Stacker Join Date: Feb 2004 Location: Oregon
| are you lookin to go fast .. or crawl ??? Trinity makes fast motors for the Maxx,,, They have two models,,,, Mild and Wild... They're 69.95 each... If you have really good batteries,, and want to go fast.. These are the motors for you... I use the Titans for crawlin,, and they work great ... |
| | #4 |
| Hi Maxx,,, How'd you like the weather today ??? I spent most of the afternoon crawlin ... Got a sunburn etc... |
| | #5 |
| thanks for the info guys, now another question, where is the best place to buy e-maxx stuff online??? thanks a lot, |
| | #6 |
| All depends on what kind of E-Maxx stuff you're lookin for ... I work at R/C Plus.com... and also buy stuff from NewEraModels.com ... you can try either one of those ... if you like .. |
| | #7 |
| Guest
Posts: n/a
| one titan with the evx, 9 tooth pinions and 72 tooth spur is more than enough torque for crawling. if you want to loose weight, get a super rooster and then you only have to run one battery. you can run the titan off the rooster, it will have plenty of torque but no punch. if you want to eventually upgrade the motor with this setup, the magnetic mayhem is very popular. |
| | #8 |
| The Wheels Keep Turning ![]() Join Date: Jan 2004 Location: Phoenix, Arizona
| forgot to sign in one titan with the evx, 9 tooth pinions and 72 tooth spur is more than enough torque for crawling. if you want to loose weight, get a super rooster and then you only have to run one battery. you can run the titan off the rooster, it will have plenty of torque but no punch. if you want to eventually upgrade the motor with this setup, the magnetic mayhem is very popular. i buy most of my parts from either the local hobby shop, they should have the stock maxx stuff you need. if not then from towerhobbies.com or if you need something special just post what you need here and we will direct you to the supplier |
| Thread Tools | |
| Display Modes | |
