Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: 1st gear only Emaxx Tranny?
Old 03-08-2004, 10:34 AM   #1
Default 1st gear only Emaxx Tranny?
Have most of you Emaxx crawlers glued the tranny gears together to rid the slop? Are you all still running high and low?
DirkDigler is offline   Reply With Quote
Old 03-08-2004, 01:14 PM   #2
It's a setup!
jason's Avatar
Default Re: 1st gear only Emaxx Tranny?
Just glue it together.
jason is offline   Reply With Quote
Old 03-08-2004, 01:52 PM   #3
I knew you had the answer but I didn't think that you were back from UROC yet.
I need to know which gears you glue together.
Old 03-08-2004, 05:14 PM   #4
It's a setup!
jason's Avatar
If it were mounted in the truck on the bottom there are 2 gears, with the shifter slider in the middle. when the shifter is pulled out it will be in low gear. You glue the slider in the middle of the gears to the low gear.
Old 03-08-2004, 07:05 PM   #5
Colt Python/SR9c
TwistedCreations's Avatar
is this how "Dirtpig" ( over on the Outer Limits RC board) locked his trans?
what does this actually help? i know they say the slop,but what is that in dumbass terms? can you throttle it easier?
TwistedCreations is offline   Reply With Quote
Old 03-09-2004, 01:55 AM   #6
DD,, , I haven't tried gluing the gears as of yet.. I did however ,, buy a 3/16 collar and pulled the shaft out and bolted the collar on... It holds it in 1st gear... Then you can take off the extra servo if you like ... Have fun
CHSRacing is offline   Reply With Quote
Old 03-09-2004, 09:30 AM   #7
That's a great idea! Does it also remove the "slop"?
Old 03-10-2004, 11:40 AM   #8
DD ,,, Nope,,, it doesn't remove the slop... Still workin on that.. . I really don't like gluein stuff together internally ... If you know what I mean ??? Friends of mine keep gluein their diffs to lock them up... They have XTM straight axles... They always keep breakin loose.. :( You hear the familiar click ,,click ,,, click.. That's one reason I try to keep refining the "E" ,,, I like the spools... Have fun,,, CHS
Old 03-10-2004, 11:53 AM   #9
I used to know the "click click click". I use Xfactor axles on one of my truck. the clicking is either the ring and pinion gears, stripping or the axle shaft coupler's grub screw has backed out. I have eliminated this by JB Welding everything together. I am opposite of you I guess! I like to JB Weld everything I can. I have yet to see an XFactor axles shaft break, nor the coupler, nor a JB Welded Differential. So, I JB Welded everthing together....diff, shafts into the coupler, etc. Works great. Only downside is that if something does break....I have to buy all the parts. Oh well.....beats tearing the whole truck down every week and tightening the grub screws.
Old 03-11-2004, 07:20 AM   #10
The Wheels Keep Turning
kevinlongisland's Avatar
if you take the tranny apart you will see what is causing all the slop. by slop, we mean the fact that you can roll the truck backwards and fowards freely before the gears engage. it happens because of how they designed the two speed tranny. they use dog gears just like old motorcycle motors did.
i hot glued the components together and it has worked fine. jk (dirtpigs from australia) epoxied his together. like him, i also removed the rest of the unnecesary components. i removed all of the high speed gears, the shifter arm, and theshifter rod. the tranny is rather light after you remove all these components and is very tight. it's worthwhile doing this mod.
kevinlongisland is offline   Reply With Quote
Old 03-11-2004, 10:58 AM   #11
Great. Although....I'm still considering leaving second gear in. I ordered a gear reduction unit, 3.8:1. I may be able to use 2nd gear when I need rpm's. We'll see!
I got the tranny installed last night with a lot of other mods too. Can't wait to finish it.
Old 03-11-2004, 12:44 PM   #12
kevinlongisland- Do you have a link to that information? I remember reading something about it a while back, but I don't remember where! :?
mascman is offline   Reply With Quote
Old 03-12-2004, 06:10 PM   #13
DD,,, would you mind sharing where you're gettin the reduction ????? The only ones I've seen are for planes... and you have to do some modifying to them to make them work... :( .. Appreciate the info ... thnx .. CHS
Old 03-19-2004, 09:58 AM   #14
i don~t remember either. maybe try outerlimits
