| | #1 |
| Rock Stacker Join Date: Oct 2005 Location: Lynchburg
| Hello, after first finding this site I knew that I just had to have a Maxx Crawler. I already had a T-maxx sitting on the shelf just collecting dust, and after doing a lot of SEARCHING Truck Base :T-maxx ESC:Tekin Rebel 2 Motor(s):Titan w/GD600 (Wanting MM) Servo(s):Bluebird / Traxxas 2055 (For testing purpose) Trans:T-maxx modified Axles:T-maxx Tires:T-maxx (Waiting on Moab XLS) WB:17 1/2" Overall Width:16 1/2" Diff clearance:3" Center Chassis clearance:5" Overall height:9" Overall weight:7 1/2 lbs. |
| Sponsored Links | |
| | #2 |
| A few more pictures....sorry did not take too many. I kind of got excited building it, and forgot about the camera. Thanks for looking, Chad |
| | #3 |
| One more thing, I am kind of stuck on how to mount up the motor/GD600. Thanks, Chad |
| | #4 |
| Rock Crawler Join Date: Jan 2005 Location: Electro's
| good work on that tuber (can't wait till mines gets here), on that gd600 mounting problem. try making some kind of motor plate behind the spur, so you have a mountin location to start with. just my suggestion. but i really like your design, you got some skills! keep it up. ka'aina |
| | #5 | |
Chad | |
| | #6 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| You have some mighty fine bending skills to get those lower tubes so curvy. What style bender do you use? |
| | #7 | |
Chad | |
| | #8 |
| AKA TOKEN ![]() Join Date: Dec 2005 Location: "Used" Mexico
| Why didn't you use a Pede tranny? Anyways so far so good. Powdercoat next? |
| | #9 | |
Yeah I am really considering powder coating it, but my buddy said that he doesn't have the color that I want (Solar Yellow, same as my 1:1 TJ). He only has black and white. He could get something really close but I would have to buy way too much for what I would be using. Anyways, thanks for looking. Keep it coming, I still need a little help with the motor/GD600. Thanks, Chad | |
| | #10 |
| Colt Python/SR9c ![]() Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| | #11 | |
| Quarry Creeper Join Date: Feb 2005 Location: Indy
| | #12 |
| Thanks Twisted, I will look into that. I would much rather have it powder coated, especially since I know someone that does it. Silvr, I will look at it when I get back home. I will be out of town on business for the next day or so. Thanks, Chad |
| | #13 |
| Rock Stacker Join Date: May 2005 Location: hills
| on my brothers truck(t maxx tranny,motor in front)we drilled a hole the size of the motor in a peice 3x5x1/2in alum.then cut a straight line from side to side at the center point of the circle.had to make some holes in the gd and mounted to the bottom peice.the top half clamps over the motor to hold it in place(think of a bmx style handle bar gooseneck).on the chassis we made some slots so the alum motor mount could be adjusted in and out tward the tranny gear.the trick here is placement,you have to be on the side,or down side of the tranny gear so you can adjust side to side.drill your hole for the motor,cut the peice,mount the motor,then you can play with gd angle to get it to the side.plus you can make your mounting holes in the gd and plate at the same time.sorry no pics,he sold it |
| | #14 | |
I am going to run some kind of body panels. I will probably use carbon fiber if I can find some locally. | |
| | #15 | |
| when your looking to see if it will fit,remember you can shape the alum down to so its not just a 3x5 square peice.we left about a half inch around the motor,so we had room to clamp the top to the bottom.and followed the gd exactly.it wasnt really that big when we finished.yea caron fiber would be cool.i just started a new one to.following the body lines of the proline jeep.i'll cut the back off behind the doors,and hack the fake winch off the front.everything else seems to clear.nice job,keep it up! Quote:
| | #16 |
| Hello all, Thank you for your suggestions. I actually had an idea hit me last night for my motor mount. |
| | #17 |
| Went out and did a little testing today.....I like the way it performed. It needs a little more speed, but the torque that the GD600 puts out is great. My MM should be here sometime this week, and I will get some action pics posted up. Chad Ok, finally got the MM installed. I also got my Moabs and Commandos on it. Did a little testing around the house and I really like the MM and Moabs. Anyways, here is a few more pics. I actually went to a rock garden that is about an hour from the house, but I left the camera at home. Last edited by flexntj2001; 01-23-2006 at 06:19 PM. |
| | #18 |
| And some more..... |
| | #19 |
| RCC Addict Join Date: Apr 2004 Location: Cincinnati Ohio
| Looks great! I like it! Throw some body panels and paint on it, and your good to go! Whats the wheelbase on it? |
| | #20 |
| Rock Stacker Join Date: Jan 2006 Location: Willamette Valley
| What tubing did you use? Nice work! Last edited by gta3wheeler; 01-23-2006 at 10:37 PM. Reason: because |
| Thread Tools | |
| Display Modes | |
