Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: EVX Mod Question
Old 02-01-2006, 09:48 PM   #1
Default EVX Mod Question
I have not actually done this mod yet, but I am wondering which set of wires do you connect the moter to? Since there is a set from each previous motor. Or either?
mxmissile is offline   Reply With Quote
Old 02-01-2006, 09:54 PM   #2
Its My Wifes Money!!!
John Deere's Avatar
What mod are you wanting to do. Also the are some write ups on this site about some mods for the EVX. Actually I seen on here just yesterday that someone asked the same question. Use the search button and look, type in EVX and that should work. Question about the EVX mod Here maybe this helps or this http://www.rccrawler.com/evx.htm. Just look over this stuff and this will save you from searching for this.
John Deere is offline   Reply With Quote
Old 02-02-2006, 12:14 AM   #3
That is the walkthrough I was refering to. And if I am thinking correctly it should not matter which set you use for the moter. I guess I'll find out for sure tomarrow. Thanx for the link.
Old 02-02-2006, 12:18 PM   #4
I have connected both sets of wires to the engine(not at the same time) to see if there is a diffrence...and there is no diffrence that I can tell.
donkeykong is offline   Reply With Quote
Old 02-02-2006, 02:03 PM   #5
Colt Python/SR9c
TwistedCreations's Avatar
There shouldn't be a difference that I know of. I just kept everything on the left to the left and right to the right, just in case. Although I haven't ran an EVX in a long time
TwistedCreations is offline   Reply With Quote
Old 02-02-2006, 03:39 PM   #6
John Deere's Avatar
Glad I could help.
Old 02-02-2006, 11:10 PM   #7
im useing the ones closest together right in the middle.red under the "n" in novak.black under the "s" in traxxas.
bipolarcrawler is offline   Reply With Quote
