| | #1 |
| Quarry Creeper Join Date: Sep 2004 Location: On my acre and a half of Gods Country. Prosper, TX
| Okay, I know I should search, but I don't have time right now. I am putting together a RockRaider chassis, with Kongs, and I am using longer links in the front than I am the back. My problem is, I have some Savage shocks that I was going to use, but I don't know how, or where to mount the shocks on the A-Arms. I have the stock a-arms. Can ya'll post up some pics of how you mounted your shocks on the axles, or at least the axle side? Thank you Mark |
| Sponsored Links | |
| | #2 |
| 31st place in 2006 Nats!! ![]() Join Date: Feb 2004 Location: Columbia Gorge
| It's changed a good amount since this picture but gives you the basic idea. I also don't run the shock mounts off of the chassis, I could but don't for wanting a lower profile setup....Although I do have some short-short shock mounts off of the chassis for the rear right now, still lower profile than the stock Rockraider 4" shock mounts. |
| | #3 |
| Well, here in lies the problem. You have RPM arms, and I have stock arms. There isn't enough meat to run these. I am thinking about just doing a link mounted shock mount. That way I could do it with the different length links, and I shouldn't have as many problems as an axle mounted link. BTW, are you just running the 4" Traxxas style big bore shocks? I have the Savage shocks, but I have some T-Maxx shocks that I could use as well. And I could take off the higher shock mount as well. Also, what wheel back do you recommend on the RockRaider with Kongs? I have this at about 17-1/2" right now. |
| | #4 |
| Thread Tools | |
| Display Modes | |
