| | #1 |
| Newbie Join Date: Jan 2006 Location: Kingsburg
| The perliminary drawings are done. I am starting the prototype next week. This rear driveline disconnect will be all internal. To lock and unlock you will have to use a servo. So if you have all three channels used up you will need a 4 channel radio or two radios. It took a better part of a month off and on to figure it out. But I think it's good to go now. As soon as it's up and running I post up a video.. |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Sep 2005 Location: wyckoff, NJ
| sounds like an awsome idea to make it internal. i would love to see this |
| | #3 |
| RCC Addict Join Date: Apr 2004 Location: Cincinnati Ohio
| Post the drawings. |
| | #4 |
| Kinda secret right now. But if I get it going I'll share. |
| | #5 | |
| Rock Crawler Join Date: Jan 2005 Location: Electro's
please share the aloha! | |
| | #6 |
| Colt Python/SR9c ![]() Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| well if it's kinda secret, why even make this post in the first place? :? |
| | #7 | |
| | #8 |
| well the thread is still useless without pics You have us all wondering. We know the idea is not new, but still wants pics |
| | #9 |
| Rock Stacker Join Date: May 2005 Location: hills
| 4thewknKinda..." secret right now. But if I get it going I'll share".why would it matter if you showed us now,or later when its done(implied above)people could possibly help ya on the" if i get it going"part too if we knew what your doing Last edited by bipolarcrawler; 02-27-2006 at 02:45 PM. Reason: quote was missing " |
| | #10 | |
| | #11 |
| So you talking about inside the trans?? If so, you will need a carrier bearing to hold the main output shaft in place. I thought about the same thing last year, but figured it was way to much work for what i wanted to do |
| | #12 |
| Did you try it? Don't think a carrier bearing is needed the way I'm going to make the shafts. |
| | #13 |
| sounds good,but i dont understand the point of doing this?why would you want to shift to two wheel drive?what am i missing here? |
| | #14 |
| Well you may be doing it different than I was thinking. I was going to cut the main shaft in 2 and use the shifting rod still. The shifting rod would slide on the shaft to engage and disengage. The only problem I had is when it disengaged the one side, it would have dropped down a bit , making realignment a PITA. So the carrier bearing would be needed. |
| | #15 | |
| | #16 | |
Yes you are right ,but what if you did this. Take shaft #1 the front shaft closest to the front axle. Cut it where it is machined down for the rear low speed gear where the bearing buts up to. Then linebore it to say 1/8" just for kicks.. Then take another shaft and cut it in half. Then turn down the second shaft to slide into the first shaft. Then no need for a carrier bearing, the shaft is the carrier. I talked it over with engineer at work and he said no problem because there is no real load on it. | |
| | #17 |
| Rock Crawler Join Date: Feb 2006 Location: Clovis, NM
| Was thinking about it but I don't have the toolage to do it. Sounds like it should work. Give it a shot and if it does, make up a conversion kit. |
| | #18 |
| yeah I never thought about running a solid rod down the center,Hmmm. I have this 2nd trans sitting here, so it may be time to just mess with it |
| | #19 |
| I'm 95% sure it will work. I know I can buy the shafts but what about the low speed gear and the shift collars? Two new trans will cost $80.00 each. Nothing on ebay either. |
| | #20 |
| low speed gears?? Are you talking 1st gear and 2nd gear? |
| Thread Tools | |
| Display Modes | |
