Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: I need a good machinist!
Old 02-28-2006, 02:48 PM   #1
Digger's Avatar
Default I need a good machinist!
I have an idea for hub-mounted planetary reduction units for the maxx, but it requires some custom machine work that is a little more in depth than I can handle on my own with my drill press. All I want out of it is the first set and credit for the idea, I really don't care if some continues to produce them for sale as long as I get credit for the design. Could anybody here handle it or know of someone who can? This would greatly reduce the strain on the driveshafts and reduce torque twist as well, since most of the gear reduction would be at the wheel....
Digger is offline   Reply With Quote
Old 02-28-2006, 02:57 PM   #2
Colt Python/SR9c
TwistedCreations's Avatar
Yes I know someone that can handle it and he works on Maxxes also. Shoot me a PM
TwistedCreations is offline   Reply With Quote
Old 02-28-2006, 03:10 PM   #3
i have a small machine shop in my basement.... 3 dimensional lathe, ban saw, drill presses, sanders and several other machines. i have a fair amount of practice on them and if you let me know what your doin i could probaly help
td
Turbo_Diesel is offline   Reply With Quote
Old 02-28-2006, 03:23 PM   #4
Digger's Avatar
I basically need 2 custom mounting plates(one with 2 bearing recesses, one on each side) and 2 custom shafts, one with a spot for a 9 tooth, 32 pitch pinion, and one with a hex-pin hole and threading for the wheel nut, cut out of a drill reduction unit's chuck shaft....
And multiply this times 4 for one truck! LOL!
Old 02-28-2006, 03:26 PM   #5
Colt Python/SR9c
the message is sent to Billy
Old 02-28-2006, 04:12 PM   #6
kliff's Avatar
A true planetary system, like that used by most H/D earth movng equipment would be awesome. I'd been thinking of smething a little simpler, using 2 gears like the old VW Van transaxles used. Similar in design and functin to a GD600.
Finding the outer, internal tooth ring gear for a planetary that size might be interesting....but this place may be of some help....
http://www.sdp-si.com/eStore/direct.asp?CP=gears.htm
kliff is offline   Reply With Quote
Old 02-28-2006, 07:25 PM   #7
keep us posted!
gregrocks90046 is offline   Reply With Quote
Old 02-28-2006, 07:36 PM   #8
Digger's Avatar
Cool link, but I've already found the 2 stage steel planetary setup complete with the outer ring with internal teeth, cheap too... Like I said, I just need to get the inner and outer gear case "caps" machined, probably out of delrin, and then a pair of shafts adapted to fit the input and output stages...
Old 02-28-2006, 09:09 PM   #9
jeepster26104's Avatar
Hey digger do you have any pics of what you are wanting to use? Send me pm and I will see what I can do.
jeepster26104 is offline   Reply With Quote
Old 02-28-2006, 09:10 PM   #10
Colt Python/SR9c
^^^ There is my personal machinist
Old 02-28-2006, 09:30 PM   #11
Digger's Avatar
PM on the way... Pics being taken momentarily...
Old 02-28-2006, 10:48 PM   #12
kliff's Avatar
Keep us posted, sounds like one he...... ain't sure I can do that here..HECK of a project!!!!!!!!!!!!!!!!!!!!!!!
Old 02-28-2006, 11:29 PM   #13
Digger's Avatar
Jeepster, you have a BIG pm coming at you! LOL!
Old 03-04-2006, 12:29 AM   #14
Digger's Avatar
Jeepster, did you get the PM? I haven't heard back from you yet...
Old 03-04-2006, 08:17 AM   #15
Nothing yet. Did you get the pm about my email?
Old 03-04-2006, 11:43 AM   #16
TEAM MODERATOR
EeePee's Avatar
Did you get my email about your PM? Or was that my PM about your email?
Maybe it was your PM about my email, or was it your email about my PM?
EeePee is offline   Reply With Quote
Old 03-04-2006, 11:57 AM   #17
RANOVRU is offline   Reply With Quote
Old 03-05-2006, 12:28 AM   #18
I got your post E about your pm for me. But was not OL to pm you to aim me so that you could stream it to me. Catch you OL later and will pm you about getting on AIM for the HU.
Old 03-05-2006, 05:45 AM   #19
Digger's Avatar
I sent you a huge PM full of pics... did you get it?
Old 03-05-2006, 07:31 AM   #20
No!
