| | #1 |
| Newbie Join Date: Mar 2004
| Will it work? Also what type of shock towers do I need, stock, custom made, or savage? Will I then need Savage A-Arms or Stock E-Maxx arms? Also if I wanted to go with solid axles, what would be good axles to use for a E-Maxx. Thanks for all you help. |
| Sponsored Links | |
| | #2 |
| Colt Python/SR9c ![]() Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| yes it will work but you do need to modify some things..i believe it was Kevin that did this to his Maxx..but custom shock towers, and need to cut some stuff off the stock A-arms.. as for axles, if you want straight axles,you can get x-factor,clods,or you can make your Emaxx axles into straight axles |
| | #3 |
| Ok what exactly would I need to do to the stock a-arms, and would I need to use one or two shocks cause I wanna use one. Also I'm going with the RC-Solutions roll cage, the blue E-Maxx one. What type of oil will I need for the shocks also? And what type of work would i need to do with the X-Factor or Clod Buster axles? |
| | #4 |
| Rock Stacker Join Date: Jan 2004 Location: Morgantown
| Good thread, I need to know this info too! |
| | #5 | |
| The Wheels Keep Turning ![]() Join Date: Jan 2004 Location: Phoenix, Arizona
http://rccrawler.com/postt414.html http://rccrawler.com/postt55.html | |
| | #6 |
| Rock Stacker Join Date: Jun 2004
| i put savage shocks on my rig and thay work good i have aluminum a arms and i did not have to cut anything but i made new uper shock mounts i used new era spring insted of the hpi |
| Thread Tools | |
| Display Modes | |
