| | #1 |
| Colt Python/SR9c ![]() Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| If you haven't seen the buildup post at all, yo can go here http://www.rccrawler.com/postt484.html and see the buildup for the most part she is done. im still have trouble with it running. The system seems to not have enough juice running through it to run the 4ws and all. everything just seems real slow and when the rear steer gets in a bind,it acts like you unplug the battery.i am gonna try a reciever pack and see if it helps( i hope) i really don't have much torque/power with a single Titan, so i may try another motor. but like i said, for the most part, it's finally done ![]() ![]() ![]() |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Jan 2004 Location: Ontario, Canada
| That is sweet though you should get soem kongs and a reduction. Other than that it looks awsome! jugg_crawler |
| | #3 |
| Quarry Creeper ![]() Join Date: Mar 2004 Location: VA
| Well Done ! Keep us posted on your juice issue. |
| | #4 |
| thanks guys I am quite happy with the BFT tires for this rig..i thought about the Kongs but they are just to big and heavy for my tastes right now. i may try and narrow a set like Pete did for my next project( that will start as soon as i figure out the juice situation |
| | #5 |
| TEAM MODERATOR ![]() Join Date: May 2004 Location: Tennessee
| That looks sweet! I just got me a E MAXX. It's a blast to play with stock. I wouldn't mind doing something simular as you. Would you have some close up's of how you made the IFS into a solid axle? That's one thing I'm curious about. Thanks Raptorman57 |
| | #6 |
| raptor-( is this the same Raptorman over on the Pirate board that lives in Tenn?) anyway, look at the link i posted above and you will see more pics of the axles |
| | #7 | |
| | #8 |
| ok cool deal, glad to see ya over here..ohh and heres' a big welcome to ya but if you don't see in those pics what ya needed, let me know and i'll snap some of what ya need |
| | #9 |
| Quarry Creeper Join Date: May 2004 Location: Hartford, Connecticut
| Great looking project!! I like the scale look of everything, and those BFT tires set if off nicely. I've seen a few rigs with converted Maxx suspension, convinced me to try my own! I bought the steel tube, silver solder, torch, etc for making a tube frame. Where did you find the square tube? Or maybe it's bar stock? Looks like steel, or maybe even stainless in the pics. Thanx for the pics, great work! Vince |
| | #10 |
| thanks for the compliment, i had fun making it but just wish it went a bit faster but owell the square is just from home depot over in the hardware section..its the 3/16 solid square metal...i didn't go stainless on it and the only Alum. is the links and steering |
| | #11 |
| well i think i figured out the main problem-i just went out and ran it and was trying to use a 7.2 reciver battery like the other post, but the light on the EVX kept blinking :? ..i found out that my rig cannot run only on one battery..i plugged the 2nd battery that was intended for the RX into the EVX and all of a sudden it came alive..i finally had power back..i now have the power back to bump over stuff..with the gearing i have 72/12 it should be somewhat quick but before you would have thought i had a reduction unit on it..top speed was about 2mph. with no power to do anything. so now i need to find out how to put 2 batteries back on to it, but the one motor still does good, except for that i just burnt it up..i thought i had been smelling something for the past couple times and smoke finally started to roll out of it and melted the internal fan. |
| | #12 |
| Pebble Pounder Join Date: Jan 2004 Location: Santa Cruz California
| Mine melted the internal fan too, and I only had been using it for 6 months. |
| | #13 |
| RCC Addict Join Date: Apr 2004 Location: Cincinnati Ohio
| Looks really good! Too bad you diddnt have it running when I was there! I might have to borrow that welder from you and build something better for my clod. Can you weld aluminum with your welder? |
| | #14 |
| Newbie Join Date: May 2004 Location: Canada
| That is one saweet rig! One question tho, what are the chances of seeing some blueprints and or better close ups of the mods for a solid axle and maybe the chassis too? |
| | #15 |
| did you look at the link above that i posted? that has some pics of the buildup..anything certain thing your looking for? if so, i can try and get a pic of that for ya. but as for blueprints adam,nope that one doesn't do alum. since i have no gas....the new welder im getting does though |
| | #16 |
| yup ive bin lookin at ur crawler for a few hours now... tryin to get mental ideas for how to do my Tmaxx, my head hurts now too, lol. where i live i have sum nice hills that get steep towards the top, so i like to build a hill climber/crawler. my problem is, should i make solid axles like u or stay with the stock suspension and try to make it better some how. also i have a few other buddies with tmaxxes and we go racing, so i like to be able to do everything with one truck if possible too. i got too many things to do and not enough to do it with :/ As my truck sits, its a good hill climber, the .21 mill in it has enough to get it to the top, but it lacks in the goin over a rock concept. |
| | #17 |
| well it is hard to have the best of both worlds. since it sounds like you mainly do hillclimbs and racing, you mainly need the speed.that is where the IFS will be best. so i would just stick with the IFS and try to make that work. you can always gear down on your clutch bell still to a 16 tooth or 18t, but when long hillclimbs are there, you will stay in 2nd gear. also, when changing spur gears, you need to re-adjust your trans shifting point( you can read that in the manual) but thats easy and another advantage to having a lower clutch bell than your buddies, you can get around corners quicker |
| | #18 |
| Rock Crawler Join Date: Jan 2004 Location: Santa Cruz, CA
| very nice rig. in a sucker for a tuber |
| | #19 |
| Rock Crawler Join Date: Feb 2004 Location: Astoria, Oregon
| If you want the most intregal of both worlds, then you will need 2 diffrent trucks for crawling/climbing and racing. But if you so desire to only use one truck then leave it IS. just do the thing kevin did. |
| | #20 |
| Rock Crawler Join Date: Mar 2004 Location: Where it's wet
| Hey skyjacker- your spelling sucks The Widow looks great! |
| Thread Tools | |
| Display Modes | |
