| | #1 |
| TEAM MODERATOR ![]() Join Date: May 2004 Location: Tennessee
| I know I can change out the pinion gears and plan to in a bit. I was wondering if a a guy could change the tranny gears. I think it would be cool to have 1st gear super low for crawling and 2nd gear a little higher for high speed running. Is there any options for doing this? Thanks |
| Sponsored Links | |
| | #2 |
| Colt Python/SR9c ![]() Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| i asked that in a post awhile back and some people replied that they thought you didn't have any gear options for inside the case |
| | #3 |
| Guest
Posts: n/a
| You can also change the spur from 66t up to 72t. Running a 72t spur and 9t pinions, it would be very low geared. |
| | #4 | |
Like I said "I think it would be cool to have 1st gear super low for crawling and 2nd gear a little higher for high speed running. Is there any options for doing this? " I plan on changing out the pinion and/or the spur. I was wanting to change the gears in the tranny also,if possable. Kinda like,take the factory 1st gear down SUPER low and leave the factory 2nd gear alone or maybe gear it up a little. I'd like to have a truck I can crawl around with and also hit some jumps at high speed for mass air time. Surely to goodness there's a way. | |
| | #5 |
| Rock Crawler Join Date: Mar 2004 Location: Where it's wet
| As far as I know, no one has found any other gears that work and I have never heard of any after market kit for this. Do the math and have some machined? |
| | #6 | |
Thanks | |
| Thread Tools | |
| Display Modes | |
