Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: Run times
Old 05-11-2004, 10:34 PM   #1
TEAM MODERATOR
Reflection's Avatar
Default Run times
What kinda run times are you guys getting?
I'm only getting about 10 minutes of run time :( I'm using Team Orion 3000 stick packs. Are these any good? Are the side by side battery packs better for any major reason? Would they increase run times.
My charger is probly not the best but it works I guess. It takes about 45 minutes to charge 1 stick pack. So,1 1/2 hours of charge for 10 minutes of driving is getting REALLY old.
I'm thinking about trying to run 2 batteries with one motor to see if that helps. Would it even work?
Oh,one more question. My Maxx is ALL stock right now. If I gear it down real low,will it increase or decrease run times? I'm kinda thinking it would increase run times.
Thanks
Reflection is offline   Reply With Quote
Old 05-12-2004, 06:54 AM   #2
Colt Python/SR9c
TwistedCreations's Avatar
Default Re: Run times
me and my buddy use pro performance 3000 batteries and as long as we were not racing, we would get 25-30 mins runtime. on my son's stampede,he gets right about the same. but if he is racing his around, then he only gets about 10-15 mins.
as for the one motor deal,i couldn't tell ya.. maybe i was just having other problems. but when both my motors got smoked,i was running 2 batteries and one motor. don't know exactly what was going on, but after that, that is when my ESC died
TwistedCreations is offline   Reply With Quote
Old 05-12-2004, 10:16 PM   #3
once I get my crawler up and running I'll time a run and see how long it will go.
MaxxZilla is offline   Reply With Quote
Old 05-13-2004, 01:06 AM   #4
My clod running an EVX and 12T, 540 Puller motors will go around 45 minutes of crawling. 30 minutes of straight mobbin
AWESOME cheap batteries here: Http://www.amondotech.com great place.
SR5Dave is offline   Reply With Quote
Old 05-13-2004, 11:38 PM   #5
hey dave, how mayn motors and batts you using?
Old 05-14-2004, 01:48 AM   #6
2 and 2, got a clod, 2 motors or more only ;) two batteries just doesn't do it for me. I might at comps, but the power is TOO MUCH FUN!!
Old 05-14-2004, 10:14 AM   #7
Alright thanks, I think I'm gunna try the 1x1 for a while see how that goes. Since I still have some plastic in the drivetrain.
Old 05-14-2004, 10:22 AM   #8
It's a setup!
jason's Avatar
I had some decent 3000 batteries and was getting crappy run times out of them. Like 10-15 minutes. I couldn't figure out why, so yesterday I finally went and bought a good charger, I discharged them , they charged them, went out to give it a try and I was able to drive my truck hard for 45 minutes!
I was really shocked how much of a difference a charger could make.
jason is offline   Reply With Quote
Old 05-15-2004, 10:41 AM   #9
TEAM MODERATOR
Reflection's Avatar
Thank you Jason,I was starting to think of maybe trying a better charger. My father in law is a wiz with electronics,where I'm a big dummy with it. He's done all kinds of engineering and stuff. He just amazes me with his knowledge. I wonder if theres a way to bump my charger up to be a little better.
Do you have your rig geared low? Mines all stock,do you think lower gears would help run times?
